Question about Frigidaire Refrigerators
Frigidaire frt21qrc (18 yrs old) has begun to not freeze ice cream and some other items. Meat that has already been frozen still stays frozen
It sits in my garage and I have made sure there is not a lot of dust and dirt on the back or underneath it.
  • 10 Answers
SOURCE: Freezer problems
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
check here
In most of the new units they now have the adaptive defrost control. It senses when to defrost based on how many times and for how long the door is opened. It's more energy efficient but there does seem to be lots of problems with the board.
Posted on Jan 25, 2008
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
  • 306 Answers
SOURCE: frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
Posted on May 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 26, 2009
SOURCE: bottom freezer on Subzero refrigerator not thoroughly freezing
the aspiring air in the freezer botton don't work... sorry for english, i am french...t k
Posted on Jun 21, 2009
I need a free manuel plus recipes for my deni 5500 soft serve ice cream maker
On the web:
Search Results
    DENI 5530 INSTRUCTIONS MANUAL Pdf Download.
    www.manualslib.com > ... > Deni Manuals > Frozen Dessert Maker > 5530
    Deni - Keystone Manufacturing Co, Inc. Ice Cream Maker Instruction Manual. ...Freezing the Speedee Freeze ® Canister Deni Soft Serve Ice Cream Maker. ... placing in the Scoop Factory, and freezing canister is as close to -20°F as possible.
Oct 02, 2015 | Deni 3400 550w Meat/food Grinder
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
Icecream not staying froze meat stays frozen though
Meat is always more dense than frozen dairy product. This soft ice cream issue usually occurs when the circulating fan becomes blocked due to overloading.
Unlike a chest type freezer, top mounted freezers use a fan to circulate to the refrigerator. If the return vents to the freezer become blocked by too many small items, or loose plastic bags the compressor may run too long in an attempt to lower the refrigerator temp,
This may cause the compressor to heat up and kick in the overload safety, further dropping the total temperature.
Mar 05, 2010 | General Electric GTR16BBSR Top Freezer...
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
May 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
May 22, 2009 | Refrigerators
Freezer not freezing
not freezing icedraem is an issue, bread not so much, different breads contain different ingrediants that may or may not freeze, forst offthough wher is unit located??? in garage??? if so be aware that it may not operate efficiently ion ambient temps lower then 55 degrees, but if this is in your kitchen i would suspect a "refrigeration"/sealed system issue, perhaps "low on charge and not able to maintain a frozen set temp. Meat may stay frozen ( for a little while anyway, but the ice cream is the first to show indications of problem
Jan 11, 2009 | Freezers
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
  • possible causes:
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
GE REFRIGERATOR
can you see thick frost on the back wall or the bottom of the freezer compartment? if you do, you have a defrosting problem.
Feb 21, 2008 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
