Question about Sony PlayStation 2 (PS2) Console
My PS needs help
I can play cd's, but when I put in a game it tells me that there is a disc error. What can I do to fix it instead of sending it back to Sony for repair at a high price.
thanks
coyneland
  • 709 Answers
Hi Coyneland,
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Posted on Nov 02, 2007
My xbox will play cd's but not dvd's or games.. And it will keep reading and reading but if u listen u can tell the disc isn't turning and idk what to do
The good thing about this error is the fact that it is NOT your dvd drive you just need to stop the heat at the back of the drive. Use a good guide or send it in for a fix.
Jun 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Fifa 09 football problem. telling me to clean disc as it is unreadable i am cleaning the disc and restarting the console but it keeps telling me to clean the disc.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
Jan 23, 2010 | EA Sports Video Game Consoles & Games
Software to burn PlayStation 2 discs?
First of all, fix your GRAMMER problem. And I don't think that the PS2 can read burned discs. In fact, I tried to do that myself; I burned copies of the four discs of a PS game (FFIX) and I put all four on the same disc. (that may have been part of my problem)
Apr 08, 2009 | Video Game Consoles & Games
Wii unable to read gamecube disc... :(
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Mar 23, 2009 | Nintendo Wii Console
Random unreadable disc errors
I had the same problem but i sent it in. They said it was the eye reader error. Or the thing that reads the disc. Try buying a brand new game and try playing it. Alot of times when i have disc read errors i put the disc in where the xbox 360 part at the top goes in facing the xbox. Try that to see if it helps.
Mar 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 error
You need to buy a disc to bly xbox games not xbox 360.
Thats quite funny. You should take back the game to the shop and get a new copy!!
Oct 09, 2008 | Microsoft Xbox 360 Console
Motorstorm 80010514 erro
your error means this according to what I could find out : 80010514 - Disc error detected. Retrying operation. Do your other games work. If so, then you may have a bad game disc. Or it may be scratched or dirty. If your other discs work, then I would try this game on someone elses unit, or check it for dirt/fingerprints. If that doesnt work, you could try a cd lens cleaner disc..it may help.
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Wii wont read discs
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
160
Dec 16, 2007 | Nintendo Wii Console
Ps 2 chipped
I have also envountered problems with dogs life, my only reasonable explination is:
dogs life is most propably written on a normal CD-R,
and sometimes a chipped PS2 struggles to read CD-R games, you will also find that older PSX games wont work either, hope this is of some help.
have a blessed day.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
