Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Help! Took Kitchenaid Superba Door off. Allen wrenches in hinge to lift out. When cleaning glass one wrench slipped into the spring getting jammed. My question, if I tap it put from the short end would this be the best way to remove it?
  • KitchenAid Master
  • 4,654 Answers
Use a magnet. I am here should you need me, Thanks John Tripp Appliance 911
Posted on Apr 22, 2014
  • Trina
    Trina Apr 22, 2014
    Thank you
3 Suggested Answers
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
  • 12 Answers
SOURCE: What tool do I need
this is a #10 torx
Posted on Aug 03, 2010
How do i get the glass out of the door of the zanussi 2KG 5530 gas oven to clean behind
Open the door to the first step. It will hold itself open. In the pivots, put an allen wrench or a small screwdriver through the bottom hole on both hinges (left AND right sides). Lift the door straight up and off the hinges. Remove the screws around the door and dismantle it. Clean the glass and make sure it's completely clean and dry. Reverse the procedure to put it back together.
It sounds complicated but it is really quite easy to do.
May 07, 2011 | Office Equipment & Supplies
I need to replace the hinges on my kitchenaid superba, how do i take the door off ?
Usually all you have to do is open the door slightly, and lift upwards keeping your fingers away from the hinges as they have a very strong spring and can hurt if they release.
Jan 04, 2011 | Ovens
Inner door glass replacement
open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Feb 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid Kadette hums and does not run
Mine does this when it is clogged, one time my daughter cleaned out the fish take and filled the disposal with pebbles. You should have recieved an Allen wrench with the unit. You will be able to put the Allen wrench in the bottom of the unit and turn the disposal manualy, this should break loose any jammed blades.
Apr 02, 2009 | Kitchen Appliances - Others
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Oven door
the hinges are very tightly spring loaded. pull the hinge out (be careful) and insert a nail or similar item in the hole that is exposed in the hinge after it is pulled out. the door will now slide down into place. just slide it down into place and remove the nails from the holes
Nov 24, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Kitchenaid superba Stove Door
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
Aug 04, 2008 | KitchenAid KESC307 Electric Kitchen Range
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
75 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
