Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes not turning and water not being picked up
    Problem Solver:
  • 5 Answers
Frozen up Turbine is a 95% probable problem. Bearings rust! Take brush block out ad insert a screw driver (size of brush bock stem)where brush block stem goes up and in. Insert and try turn screw driver. Should turn fairy easy, some resistance because gear driven! Common problem! Can buy turbine on Ebay but be careful you order the right one for your model. They look the same but 5 brush and 6 brush turbines are different. Think I paid about $36 for one and did it myself but not the easiest. Good luck!
Posted on Apr 22, 2014
  • JoeVacs Apr 22, 2014
    A better solution is take it to your local vacuum cleaner store and have them repair it. I repair these all the time. I disassemble the turbine and re-grease the bearing. It saves you money and is better than new. The other issue is not related though. If it won't pick up the water you most likely don't have the front of the lower tank latched properly.
Brush not turning
Your brush is likely jammed with pet hair or other stuff it's picked up. Check the ends of the brush, where the bearings are, and clear the stuff jammed in there.
Jun 12, 2015 | Vacuums
Tip
When I called they indicated that the brush roller can be removed with a...
Keep the brushes cleaned regularly. I used a pick to pull out the hair and dust bunnies. It took a while, but will be easier if done regularly.
I tend to want to wash everything with soap and water. They recommended not using water.
on Sep 23, 2013 | Dyson DC35 Multi Floor Digital Slim...
"Power Brush" attachment doesn't work
When my hover suffered a similar issue i found the problem to be a little stone caught in the part you described as a water wheel, however later i found that one of the connecting hoses from the front of the hover had a little blockage , later, i actually washed the filters and left them to dry over night wrapped in a towel on a warm heater, it was back to normal , the last hover gave in as the motor started to slowly give in , it could be this
Mar 15, 2014 | Vacuums
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it...
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Oct 01, 2010 | Eureka Vacuums
Steamvac will not **** up water
Check the lid on the lower tank. The front of the lid lips over the tank to lock it on and snaps in the back. You probably haven't locked the front edge down
Apr 29, 2010 | Hoover F5810 SteamVac Upright Vacuum
Brush nopt turning - only picks up a bit of dust
did you check the belt if it is broken replace it that should do it
Feb 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
IRobot stopped picking up larger bits from the carpet. It picks up the dust, but anything larger, it leaves behind. Have changed the filter/brushes. Is there anything else I need to do
Its sounds like the brushes aren't turning. Pull the vacuum and bin off the back and start it and look to see if the brushes are turning.
Sep 29, 2009 | iRobot Roomba 560 Robotic Vacuum
I have a Eureka Whirlwnd bagless upright vacuum. It can pick up the dog hair but does not pick up the dirt anymore. What can I do?
Check the hose and dirt inlet by the brush roll for a clog. Also check your brush roll, do the ends turn freely, if not replace it, you may need a new belt, it may not be turning the brush roll under load. They stretch after awhile and will slip.
Apr 19, 2008 | Vacuums
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Not dispensing soap; won't pick up moisture.
Check the filter on the bottom of the lid for the dirty water tank, make sure it isn't pushed all of the way up, needs at least a gap of 1/4 inch or so. Also make sure that the lid for the tank is locked down and not loose on one end.
Sep 10, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
