Reset maintenance light on toyota highlander 2004
  • 38 Answers
Not sure if this works on Toyota, but try turning the key to the on position without starting the engine and quickly pressing the gas pedal 3 times.
Posted on Apr 21, 2014
Turn light will not turn off, not blinking, When turn on signal or 4 way flashers goes off for a few seconds then comes back on
2006-2015 Toyota Highlander MAINT REQD Light Reset
seventrumpet.com/2006-2015-toyota-highlander-maint-reqd-light-reset/
Mar 15, 2015 - How to MAINT REQD Light Reset on Toyota Highlander 2006, 2007, ...Turn the ignition switch to the "On" position, but do not start the engine ... This procedure should applies to the second and third generation of the Toyota Highlander (2005, 2006, 2007, 2008, ... Your email address will not be published.
Oct 12, 2015 | 2005 Toyota Highlander
2004 toyota highlander abs and brake light stay on and it will not shift
hi there..... if you have a abs light on this means there is a problem
with the abs. and its usually a wheel sensor. but could be one of several problems. the only way to remove the light is to repair the fault
that is something that's isn't within the scope of the diy motorist.
and would require a visit to the professionals. only then will the light be
reset. and go out.
Nov 22, 2013 | 2003 Toyota Highlander
My 2005 Toyota highlander is showing on the dash board maintenance required, but when i scan it with the scaner nothing was found. what shall i do?
its time for a oil change. to reset the light the odo has to be on current mileage not trip a or b. with the car off push in the stem for the odo and hold it and then turn on the key the numbers will disappear and return when they do you are reset. the light will come on again in 5000 miles.
Oct 06, 2011 | 2005 Toyota Highlander
Had my oil changed and the maintenance required light wont go out
Usually you turn the key off push the trip odometer reset button and hold it in turn the key to the on position but don't start the vehicle.Where your mileage usually is and where your trip meter reading is you will see like 5 or 6 little lines that will disappear one at a time and when they all are gone you can let go of the reset button and light should be off.
Apr 13, 2010 | 2004 Toyota Highlander
Maintenence required light and tire pressure lights will not go off after oil change and tire rotation on my Toyota Highlander. How do I turn them off?
The maintenance light needs to be reset manually. See my Tips and Tricks on this website for additional information on how to reset it.
You should also check your spare tire for proper inflation. It will set the tire pressure light, as the spare is monitored also. If all 5 tires are OK, you may have a malfunctioning tire pressure sensor. If the tires have been changed recently, people with older tire machines have been known to break the sensors regularly, by mistake.
Aug 10, 2009 | 2009 Toyota Highlander
Need to reset the "Maintenance Required" light on the dashboard
Revised procedure (for Highlander)
Turn ignition key to 'ON' and press the odometer button until the display reads actual mileage... not Trip A or B.
Turn ignition key to OFF.
Hold in the same button you used in step 1.
While holding the button in, turn ignition key to 'ON'.
The 'Maint Reqd' light should blink and go out.
May 09, 2009 | Toyota Sienna Cars & Trucks
Computer warning Oil maintenance 2008 Highlander Hybrid
Please email me on onifadeadewunmi@hotmail.com and I will email you the procedure in printed matter.
Cheers
Apr 14, 2009 | 2008 Toyota Highlander
Reset oil maintenance light in 2008 toyota highlander
  1. Set the "ENGINE START STOP" or engine switch OFF with the trip meter A reading shown.
  2. While pressing the trip meter reset button, set the "ENGINE START STOP" switch or engine switch ON.
Without multi-information display
  1. Continue to press and hold the button until the trip meter displays 000000.
With multi-information display
  1. Continue to press and hold the button until "COMPLETE" appears on the multi-information display.
there you go jimmy mark as fixya
Sep 26, 2008 | 2008 Toyota Highlander
16 people viewed this question
jasbo
jasbo
