Question about Whirlpool Mastermind
Power controll card a 2290 240008
Power will comes fridge giving a sound like hooter sound we stop the fridge after 20 minute fridge start it will start or otherwise hooter sound will come what we will do
  • 67 Answers
Try cleaning the condenser section, under the unit there is a fan that may be dirty or hitting something, clean it out.
Posted on Apr 25, 2014
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
The fridge stopped working last night. The light works, but the fridge just makes this clicking sound every couple of minutes, doesn't sound like anything is running and it does not get cool at all. Any...
Not a good sign, clicking. Usually that click comes from the compressor power circuit. The compressor is attempting to start but it does not. The clicking is from an overload protector that heats up from current draw. It clicks and cuts the power to the compressor, cools down, and the cycle starts again. Could be a start capacitor went bad, but it is probably the compressor.
Mar 11, 2015 | Refrigerators
My ford bantam 2005 1.3 is making a hooter noise while driving
sounds like a joke post but I will humor you.
Unplug the Hooter (must be a South African) and see if the noise stops. Also check that the bolt holding it on is not coming loose. Some horns (hooter) make that sound if they vibrate.
Mar 01, 2015 | 2005 Ford Bantam 1.3i
My samsung refrigerator goes off everytime the electricity flickers, even for a flash or less than a second. It goes off and it does not comebacks on for as much as 24 hrs. Sansumg's technitions says...
The fridge can cut off if there is a power flickering or variation as the relay will be energised to trip off. Once the fridge is off the self timer - 5 minutes- will be active to allow the gas/oil to come back to the compressor as the flickering would have produced an irregular pumping.
After about 5 minutes the processor will energise the relay to contact and start.
Now the main issue is the voltage in your household. if the voltage is low then the fridge will not start again as it will click and shut off. So make sure that there is sufficient voltage in the mains supply. Also the plug point where the fridge is connected must deliver good voltage/current as the wiring must be good to carry the load . If not the fridge will trip off whenever there is a power flicker.
Finall if the power is good then the fridge mut be checked as it cannot be off for 24 hours. register you complaint for warranty service.
If power is irregular use an auto- voltage stabiliser .
Aug 09, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
My double door frig gets its air passage blocked again and again with ice and it stops cooling. When the ice is cleared either opening the freezer back, or shutting it down, frig starts working, but in...
Hi!!
Let's try this:
Check temp. settings the freezer knob controls thermostat settings, set it about one third of the scale.
The fridge knob, (set it half way) controls a door actuator that lets cold air blown by the little fan in freezer go from evaporator (the one that gets iced up) to the fridge, so, the little fan in freezer is the one in charge of making your fridge work. CHECK FAN, it should come on when you open freezer door for a couple of minutes, it must sound strong, and if you put your hand in front of one of the fridge's air vents you should feel cold air coming out, if no or weak breeze comes out, check passages for obstrucion, if none, replace motor, (about 20 at your hardware store)
I assume your mechanic already checked thermostat and defrost operation, because, if your timer is right, the defrost mechanism will de-ice the evaporator about four times a day.
Check your drain hose for blockage.
Let me know how it worked out, good luck.
If helpful, click below
Apr 03, 2010 | GE GSL22JFR Side by Side Refrigerator
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
My Kenmore side-by-side refrigerator keeps
you have a bad control board. if its less than a year old it should be under warranty still. if its over a year the board is fairly easy to replace yourself. you can look up the part at partsdirect.com and if you'll give me a complete model number I'll give you step by step instructions for replacing it. thanks peyton
Mar 10, 2009 | Kenmore 53352 / 53354 / 53359 Side by Side...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool Mastermind Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
