Question about Nikon Photography
Nikon f60 door broken
I am looking for a way to repair the door. The little tiny pieces that are supposed to be locked for the door to remain closed are broken. I am looking for a good and precise picture in order to repair the door by sticking tiny plastic pieces to the door in order to be able to close it again. Thank you for your attention.
  • psnaydenov
    psnaydenov Apr 21, 2014
    To be more specific... I am looking for a picture of the door. A picture of these tiny pieces that actually lock the door. I plan on cutting new tiny pieces and glue them to the door and thus imitate the real thing. It should be fine as long as the door remains closed when pushed.
  • Michael Sartin May 08, 2014
    Have you considered replacing the door? I am doing the same thing today on an f65. The screws are very difficult to get out of the base of the camera. I had to take mine to a jeweler, but when you have access, there is just a single hinge pin to pull out.
    Novelist:
  • Nikon Expert
  • 357 Answers
Two, one on top and one on bottom
Posted on May 14, 2014
5 Suggested Answers
CameraRepair
  • 60 Answers
SOURCE: Broken latch on hinged back
Try calling Canon's parts department at 1-732-521-7230 and see if they still have the part in stock. The part number is CF1-3129-000 and should cost less that $2.00 I think.
CameraRepairs
Posted on Aug 11, 2008
  • 571 Answers
SOURCE: Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Posted on Aug 18, 2009
cammedic
  • 667 Answers
SOURCE: Back of camera will not close
Yes, the film door was always a problem on these. The entire door was usually replace since it was one piece with the latch.
I do not believe that Nikon supplies the part any more. You can check eBay for a dead camera, or possibly a new /used door.
The other option is a repair kit available from USCamera.com
Posted on Dec 14, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a nikon fm10..when
Does this fault happen only with that lens? Also, you're wrong about the shutter: it appears you're mistaking the shutter assembly for the lens diaphragm (also known as the "iris").
Older lenses often have sticky diaphragms, usually due to oil migrating onto the individual blades and sticking them together. A sticking diaphragm can interfere with the shutter operation on some SLR's.
Fixing a sticky iris is usually a professional job, but if you're careful then with a simple non-autofocus lens like yours it's often possible to do on a DIY basis but will be very fiddly. The object is to get to the iris blades and to then thoroughly clean them. They're Teflon coated so should slide over each other without lubrication, but their pivots normally need the tiniest bit of lubrication. If you try and fail then you've lost nothing as the lens was effectively scrap anyway and there are plenty of cheap/free replacements around.
Posted on Sep 10, 2010
Where can take my DSC-W1/W12 Battery door
I have several of these little Sony cameras and had the same problem with the battery door not latching on or locking up. If you want an easy fix, just look for your camera model number on Ebay and some sellers actually sell the complete battery door. You can also buy a For Parts Only camera with the same model number and use the battery door making sure it is intact of course? I doubt you can find or buy a battery door through Sony any more, a repair shop would charge an arm and a leg for such repair and that is if they even have extra parts for a camera that old?
I fixed one of mine by cutting two small pieces of a sewing needle, yes i know it souds corny and all but it worked. What usually breaks on these camera battery doors is 2 small tiny plastic tabs that that latch on to 2 tiny tabs attached to the camera body, when the door tabs break off theres no way the door can lock and so it just hangs open. I decided to measure 2 pieces of metal, more like rods from a needle and heated the tip and pierced through the battery door matching those tabs underneath. You do have to be very patient and careful with this as you don't want to miss the angle where the original tabs use to be. I did fix my camera even though you can see 2 tiny metal rod inserted through the battery door but it held up real good and still working.
Nov 18, 2014 | Sony Cyber-Shot DSC-W1 Digital Camera
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
Nikon D40x camera flash faulty
Depending on exactly which piece is broken, you can order the flash top cover and/or the flash head assembly.
Dec 24, 2011 | Nikon D40x Digital Camera
Battery door won't stay closed
www.thefotogeeks.com sells battery doors for the Nikon L20.
Mar 31, 2010 | Nikon COOLPIX L20 Digital Camera
Can't load the film in the F80 leader won't take up
Open the camera-back. Look to the right where the take spool is there is a red mark. The leader should go to the red mark not any more. Now look at the inside of the camera-door, you should see close to the hinge a springy thingy-bob. If that is missing then when you close the door there is nothing to push on the film to seat it. On that spring is a chrome pin as well. Hope this helps you.
Mar 14, 2010 | Nikon F80 35mm Film Camera
Back of camera will not close looks like small piece of plastic has broken
Dec 14, 2009 | Nikon N6006 35mm SLR Camera
Aug 08, 2009 | Nikon F60 35mm SLR Camera
Nikon D200 battery door - is it broken?
The battery door is meant to come off so the MB-D200 battery pack can be inserted, but it sounds as if yours has broken. There should be equally-sized rods that form the pivoting hinge, on on top and one on the bottom. Yes, you can buy a replacement part, probably through a local dealer or online. I believe online they cost around $20-$25. To remove the door, you are supposed to open the door to a 60-degree angle to the camera body and gently pull the door off. To replace the door, again, hold the door at a 60-degree angle to the body and gently press it into place. Or you could pay a repair shop an arm and leg to do this for you ($50 or more + shipping if you use a mail order repair shop).
I remember the 'good old days' when film SLR's were made to take a beating. Sadlly, we're in the era of plastic and I always have to remember to treat every piece of equipment as if it were made of glass!
Hope this helps?
Dec 13, 2008 | Nikon D200 Body Only Digital Camera
Battery door and latch broken
Have used a 5-cent nylon cable tie for years on our CoolPix 990 and it never has failed, and still allows for battery changes. Looks a little funny to some, but is very functional. Don't know if your camera's design is similar enough for this to work, but it may worth trying.
Oct 29, 2007 | Nikon Coolpix 3200 Digital Camera
Photography Logo
52 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
