Question about Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV
Screen is black, but still getting audio
The screen is very dark, if you look closely you can see an image, but the screen is almost black. I'm still getting audio without any issue. This issue is on all video inputs.
  • Samsung Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 21, 2014
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Light and dark?
The video invertor board needs replacing.
Posted on Jun 25, 2007
SOURCE: BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Posted on Jan 16, 2008
welcomejee
  • 10594 Answers
SOURCE: I Have a Samsung flat screen ser# LNS4692DX/XAA
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On
Do you get Menu screen now or tv shows channels?
If problem still not solved then let me know how old is this tv and any related info about problem like storm or lightning in area that caused this problem in tv. Does tv show picture in dvd playback?
Thanks.
Posted on Nov 04, 2010
cadillac02
  • 318 Answers
SOURCE: Hi. Lately my tv is turning on but once the video
This is a foreign voltage issue. It's very high voltage with minimal current. Milliamps to say the least. It is not dangerous. The only way to test for this voltage is with a foreign voltage tester that low volt techs and electricians use to identify charged or hot lines. You can dump this foreign voltage over the coax cable coming into the house as long as the coax cable has a ground block outside where it comes into the house. If the DTV and XBOX are unplugged you say that it doesn't do it, correct? What other peripherals do you have plugged i when you unplug these two? Well, if that's the case then the problem is not your TV it's either the XBOX or the DTV. I diagnose these issues for AT&T Uverse and have come across similar situations like this one. How this voltage comes across the frame is too complicated to explain in this forum. First, determine whether or not it does it with just the DTV box hooked up. Isolate the problem down to the particulars. This voltage will pass over any connection between the peripheral and the tv. this voltage will cause other small problems like voice and video not sync'd, delay on channel changing, automatic shutdown of individual peripherals, etc. Do you have any of these symptoms? I can help you, but we need to establish a question answer forum to go further. Answer these questions and try to get more troubleshooting data. Excellent narrative by the way. Let me know.
Posted on Jan 26, 2011
Testimonial: "Information was helpful. It gave me another option to pursue and problem solve. Something I hadn't thought of yet. Thanks so much!"
I have compaq MV7500 COLOUR monitor n when i turn on the screen then i m getting only white line in the middle on the screen how can i fix the problem
When the following conditions, you need to replace the LCD screen:
No image on the screen, but the power indicator stays in
Dark display but still readable
Results - 1 of 1 / from by by 2 to a few seconds are of the the the the scintillator of the screen and Close for between the
The power indicator has been lit, but nothing display and sound
No image on the in the screen, but the LCD TV still comes with audio
Pictures cycle open and close the, as well as lamp closed for non high-power LED
http://www.lcdinverter.info/hp-pavilion-dv61247eo-lcd-inverter-p-11136.html
May 15, 2013 | Computers & Internet
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
Screen stays black when power comes on
Audio really does not matter here---in a very dark room shine a flashlight at the screen with set on to see if you see a very dim image on the screen or not.
Oct 29, 2012 | Proscan 32LB30QD 32 in. LCD TV
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
Aug 05, 2010 | Mitsubishi Computers & Internet
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Olympus Fe-4000 screen is completely black no image available
Stephan is exactly right. I have a FE-4000 and the LCD screen is most likely dead. As Stephan said, the screen should be replaced by a professional.
Cheers to all
dmklunk122
Dec 16, 2009 | Olympus FE-4000 Digital Camera
My 26 inch insignia has sound but black picture
Hi freelingtrapt,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 22, 2009 | Insignia LCDTV26 26 in. Television
No picture, just audio
Hi
Jan 20, 2009 | Philips 50PF9956 50 in. HD-Ready Plasma...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV Logo
435 people viewed this question
Jerry Greenberg
Jerry Greenberg
