Question about Sharp Office Equipment & Supplies
Sharp EL-1197S Calculator's paper roll doesn't advance
I know it's old, but my Sharp EL-1197S printing calculator still works except that the paper roll doesn't advance consistently. It will print 3 or 4 numbers then stick and print the next 2 or 3 on top of each other. It probably just needs a cleaning, but there isn't much I can see that could be preventing the tape from advancing. Any ideas?
informatica
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
ginko
  • 19396 Answers
SOURCE: Sharp EL-1801V Calculator
The manual for 1801v is not distributed from Sharp anymore.
You can download the manual for EL-1801PIII Operation Manual (240K) , It is the same model with some cosmetic difference.
Regards
Posted on Apr 02, 2008
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Trying to replace the paper roll on a sharp EL1801V
1 Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    How do you put the adding paper into the machine? My machine is a EL-1197iv
    Never insert paper roll if torn. Doing so will cause paper to jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig. 2)
    3) Insert the paper roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Jan 03, 2011 | Sharp EL-1197PIII Calculator
    Replacement paper roll size???
    Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
    Sep 26, 2009 | Sharp EL-1197PIII Calculator
    I have a TI-5045 II Calculator that wont print
    I have the exact same problem (just happended recently) with my TI-5045 II after 25 years of good service. My solution? I just bought another model: Sharp EL-1801V at Stapels for about $31.00. To get the old one fixed will probably cost me $25.00-30.00 just to diagnose, plus shipping and parts and labor. And that assumes I can find a shop to do it, or that TI still stocks the part(s) gone bad. Same old problem with all technology.
    Sep 16, 2009 | Texas Instruments Office Equipment &...
    How do I add paper to my sharp EL-1750V calculator?
    Download the Operation Manual for your sharp EL-1750V calculator from here:
    http://www.sharpusa.com/products/TypeManuals/0,1083,16,00.html
    Check the section "Paper Roll Replacement" (it has some images).
    Jul 31, 2009 | Office Equipment & Supplies
    Tape wont register on this after we changed the tape
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    Sharp EL-2196BL
    mechanism.
    197 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
