Question about Kenmore Dryers
Repair t 4000
Dryer does not dry clothes. Heat element comes on fo a few seconds when first started and that it. The gas valve is the open position. All lent has been vacuumed filters and ducts.
  • 38 Answers
You did not state whether the flame ignites or not. If it doesn't, the check to make sure the gas line to the dryer is not turned off. You should hear the gas valve "click" while the ignite is glowing.
You can "crack" the gas line at the value to make sure gas is going to the valve.
If you have gas at the value, and do not hear the click, then the gas valve is not opening. Either the valve or the controller is not working.
If you are getting a flame but it goes out quickly, then it is possible the flame sensor is bad.
If you do not feel comfortable doing this, call a qualified appliance repairer technic
Posted on Apr 21, 2014
SOURCE: Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Posted on Jan 06, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Posted on Jun 11, 2009
  • 1129 Answers
SOURCE: my dryer takes forever to dry clothes. A typical
Wrong valve or defective unit
Posted on Jul 15, 2009
MNTECH
  • 1543 Answers
SOURCE: Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Posted on Sep 10, 2009
Testimonial: "Yes this was very helpful and just the answer I was hoping to get. You saved me the cost of a new dryer"
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
How can i repair the dryer when it wont heat. It heats only in the beggining then it does heat anymore more after 10 minutes, how can I fix it?
I was dealing with this exact issue for the past few days! I have a model # MDG5500AWQ. Starting to hang dry clothes and all. I read through these blogs and found that it was a GAS VALVE SOLENOID COIL that I needed to be REPLACED. I was told by a Magtag dealer that when the gas flame cut out like this the issue was 99% of the time the gas valve solenoid coil kit. I was even trying to call around to try and get a tech out today but none were available and they wanted $65.00 just to come out and look at it. So I went to the Magtag website and found a dealer in my area and asked them for the part. If you open the front part of the dryer and push the button to make the dryer turn on without the door closing it in a few seconds the flame starts on and about 1 minute later the flame totally cuts out. My husband just got through changing out these coils which were smaller than the picture, only $35.00 with tax front the dealer, and located in the very front of the dryer,. towards the bottom, when you open the dryer front. He replaced them and I'm drying a load of laundry right now, thank God!
Apr 05, 2010 | Roper REX4634KQ Electric Dryer
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
Clothes won't dry, works sometime.
Either a bad flame sensor or bad coils on the gas valve assembly.
Jun 01, 2009 | Kenmore Elite HE4 Electric Dryer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
GGW9200 Dryer Does Not Dry. Status Light goes immediately to Wet
if the heat is only staying on for a few seconds and cutting out the vent line could be clogged,pull out the dryer,remove the vent line from the back and start it,if the heat stays on the vent is blocked,this is the easiest thing to start with,if the vent is clogged you can try a leaf blower and blow the lint out of the vent line
Aug 06, 2017 | Whirlpool GGW9200L Gas Dryer
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
41 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
