Question about Nelson Sprinkler: Traveling Tractor
1865 spray arm replacement - Nelson Sprinkler: Traveling Tractor
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
Sprinkler arms came off and water shoots straight up
You just have to screw the arms back on. There is a plastic white bolt that is attached to the arm it screws on to the tractor.
Sep 04, 2013 | Nelson LR Rain Train Traveling Sprinkler...
Nelson RainTrain doesn't move forward
Hi, loosen both arms and roll them in the other direction and re tighten, basically the water is rotating them in the wrong direction, regards Phil.
Jun 07, 2012 | Nelson LR Rain Train Traveling Sprinkler...
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
The unit runs backwards
Hi, loosen the arms and rotate them so when turned on the spray arms spin the opposite direction to what they do now. Regards Phil.
Jul 23, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Where can I get parts for tractor
http://www.sprinklersupplies4less.com/traveling-sprinklers-nelson-1865-replacement-parts-c-384_627.html
Part suppliers are very limited for this item. And it was the only place I found other than the LR Nelson manufacturer.
Jun 06, 2011 | Nelson Sprinkler: Traveling Tractor
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Nelson Sprinkler:  Traveling Tractor Logo
111 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
