Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer says ad stops mid dry - Frigidaire FEX831CS Top Load Stacked Washer/Dryer
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Imadesigner Custom,
I see that you are receiving an AD error code on your laundry center, model# FEX831CS, and your dryer is stopping mid-dry. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your dryer, if it is still showing an AD error code, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Posted on Apr 22, 2014
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
My dryer stopped mid drying cycle. The breaker in
Your dryer has an overtemp safety. Called a high limit, it has 2 wires connected to it, and usually is held in place by 1 screw. There will be a couple of them, the one closest to the element will be the bad one. It looks like a suppository, you'll see if you open up the unit yourself. DISCONNECT ALL POWER BEFORE ATTEMPTING ANY ELECTRICAL REPAIRS!!!!!!!!!!
Apr 11, 2010 | Maytag Performa PAV2200
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer stopped drying.
check thermo fuse in rear, kills motor and heat, white in color. Not resettable, must be replaced. ck with multimeter.
Apr 26, 2009 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
