Question about Exercise & Fitness
Nordictrack viewpoint 2800
Reason why incline not working in this nordictrac viewpoint 2800
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
2manyhobbies
  • 129 Answers
SOURCE: on my nordictrack a/2350 the incline stoped
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
Posted on Dec 15, 2010
2manyhobbies
  • 129 Answers
SOURCE: I have the EXP 2000 NordicTrack incline treadmill
Manuals can be downloaded at http://www.iconservice.com/CustomerService/manuals
First perform an incline calibration.
Insert the safety key/magnet. Press the incline up button. While the numbers are changing, remove the key. Release the incline up button and reinsert the key/magnet. The machine should go to the top and then back to the bottom.
If it only starts then stops, the incline sensor may be defective. Be sure all the plugs are secure on the controller board.
If the sensor is defective, you will need to order a new incline motor..
If the incline motor does not move at all, the controller may be defective..
I have a viewpoint 3500 nordic track and the screen doesnt work. how can i fix it?
Did you get this fixed? I'm having the same trouble now and can't find a solution any where!
Sep 10, 2013 | Nordic Track NordicTrack Viewpoint 3500...
Removing motor cover on a viewpoint 2800
fitnessrepairparts.com will give you full diagrams
Nov 24, 2012 | Nordic Track Nt Viewpoint 2800 Rear Roller...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
Viewpoint 2800 the belt is not run
If the incline works but the motor fails to run, the unit has a faulty motor controller.
Jan 15, 2010 | Nordic Track /proform Treadmill...
Viewpoint 2800 model# NTL14905.0 none of the keys respond. TV goes blank or has just red screen
Remove the cover to the motor compartment. Check the red LED on the LMCB. If it is lit constantly and not flashing in any manner, it is the console that is bad. The console runs $1600.00 which is more than the cost of the treadmill originally. Sounds like you are SOL unless you can find a used console somewhere. Good Luck.
Jan 04, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
