Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd-57734 status light solid
TV powers up, shows me a picture for about 30 seconds. Then cuts off and status lights stays lit with lamp light flashing. What could be the problem?
  • Carlton Tillery
    Carlton Tillery Apr 23, 2014
    This was the scenario. I was viewing the TV when there was a power surge that cut the power. When the power was restored. TV was showing as normal for about an hour then it shut itself off. I hit the system reset button and it comes on with picture for about 30-60 seconds. My previous comment is what the condition is now. Can anyone help?
    Sergeant:
  • 418 Answers
Remove lamp door and check lamp.
Posted on May 16, 2014
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
SOURCE: flashing status light
Wow I may have just fixed the flashy yellow status light problem. It's so siple yet so difficult. Looking at the front of your T.V. on the left hand side bottm there is a door for a filter. SMACK IT. if the door isn't shut all the way that status light will flash. Mine is turning on now, just have to work on the major problem now :) Hope you have the same simple problem.
Posted on Dec 20, 2008
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
Posted on Feb 15, 2010
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Mitsubishi 57734 shuts off occasionally
Hi,if your tv is between 1yr-2yrs maybe its time to replace the lamp.This will be the part # 915P061010 you can find it on discount-merchant with the Philips lamp which last longer 2-4 yrs 6000-8000 hrs.
Sep 24, 2009 | Mitsubishi WD-57734 57" HDTV
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Jun 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
