Question about Dynex Televison & Video
Dynex TV came on black and the buttons aren't working?
My Dynex TV was working fine when I turned it on, but when I put in the numbers to change the channel, the channel came up black, but the TV is still on. It didn't even show the number of the channel and none of the buttons on the remote or the TV itself are working. What happened and what should I do to fix this?
  • Dynex Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 21, 2014
Testimonial: "I was hoping it wouldn't come to that. It appears to be stuck between channels. Is there a reset button of some sort on the TV or remote?"
  •  Mike M
    Mike M Apr 21, 2014
    Sometimes there are a series of button presses that will reset the set, but generally it's not information the tv maker publishes. What you describe is a component failure.
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
Posted on Sep 27, 2008
SOURCE: Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
Posted on Nov 03, 2008
leecom72
  • 4806 Answers
SOURCE: Sabre 42 in plasma tv stuck on component 1
remove the power from the wall and leave the TV off for at least an hour, the static charge may have shorted the circuit board for the pront panel controlls.
after an hour or so plug it back in to see if has reset itself
hope this helps
regards
Posted on Nov 27, 2008
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Dynex dx-40L261A12 won't turn on. Red power light is on, but no sound from speakers and no picture. Remote power button and power button on tv doesn't turn the tv on.
In this case, the symptoms you describe is a faulty inverter board. The TV will or should flash "PLEASE WAIT" and then you have a black screen no audio. Find Shop Jimmy on line. Enter your TV model number. You will find an inverter board for $24.95 plus $9.50 shipping. When you remove the back cover of the TV, look to the left. You will see a long vertical board...this is what you will replace. Thanks for asking, Matt of Martins TV Repair.
Oct 15, 2013 | Dynex DX-L42-10A 42 in. LCD TV
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
I have a Dynex TV and Dish Network receiver. Last year the TV worked fine, I don't think I changed anything, but this year the top of the screen is cut off when I watch NFL games. The top of the score...
You will need to press the "Format" button on your DISH remote This button will have a * on it. By pressing this button repeatedly, you can change the format of the screen set it to normal. Next grab the factory remote for your TV and try the different formats most likely normal will work best on this setting as well.
Daniel Busa
DISH Network
Customer Service
Aug 27, 2011 | Dynex DX-LCD37 TV
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Sep 28, 2009 | Dynex DX-LCD32-09 LCD TV
I plug in headphones, but sound still comes out of TV speakers
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV? o Connect the headphone cable to the headphone jack on the side of your TV. o The sound will be heard through both the headphones and on the TV speakers. o Press Mute to hear sound only through the headphones. o Use the volume buttons on the remote to adjust the volume level. o You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
Jun 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
132 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
