I have water pooling in a catch pan under my furnace when AC unit is in operations??? I am getting cold air from the vents... Anyone know what the cause would be??
  • 66 Answers
This is condensation from your a/c running. This is the secondary catch pan which means the primary drain is clogged with algae and not draining, running into the overflow (what you see).
When they plumbed the main drain they should have left a "T" in the pvc line to allow for servicing it. A lot of people will pour a 1/2 cup of clorox into the line every 3 months or so to keep the algae clear. There is probably something more user-friendly at one of the big box stores.
I have a little air tank that I fill with air and disconnect the line and forcefully blow it out. Problem solved.
Good luck.
Posted on Jun 19, 2009
Where is the filter on my Central Cooling Air Conditioner York LR49182C (Serial no. EFFS160427) (Model no. M/HD036SC) ?
Your furnace filter or A/C filter is located next to the floor in your cold air return into the furnace. Your other problem is your condensate line out of the A/C box that sits on top of your furnace is plugged. Replace your filter in the cold air duct, and remove your condensate line from the A/C box and blow air in the line to remove the clog in the line.
Jul 20, 2015 | Heating & Cooling
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
Jun 27, 2015 | LG LWHD1800R Wall/Window Air Conditioner
Ac vent selector wont swich
not sure why you want to bypass it , this gismo moves damper under dash to allow wether you get cold or hot air out of vents depending on what you select on dash control (hi /low vents) if theres a problem with it most times it comes from ac condensate collection pan drain clogging up and water spills over into duct work rusting the damper shafts making it impossible for damper movers to move them , producing a fault or hot or freezing cold air all the time , sorry no easy fix for this but removing underdash ductwork and cleaning / replacing them lots of hours upside down with your feet on seats and head under dash , just kidding ...... most times we just take front seats out that makes plenty of room
May 13, 2014 | 1994 Buick LeSabre
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Jun 06, 2011 | GE AEV05LN Air Conditioner
The haeir window ac unit is tilted to the back but the water won't drain it is spraying out the front vents when running
From what you have described, it sounds like the drain pan under the unit is clogged. Cleaning and unclogging it, should solve the problem.In the meantime, discontinue using the AC until the problem is solved. As the water spraying out the vents, could cause and electrical short in the unit. That's in addition to getting water on your floor.
May 12, 2011 | Heating & Cooling
Does drip pan need to cover entire furnace or just coil. I got both answers for repair men.
When you say drip pan are you refering to a pan located under unit in case drain plugs ? If this is what you are talking about and you have a furnace that is 90% efficient or more which will be vented with pvc, it needs to be under the whole furnace as condensate water also comes from furnace when operating and if this drain plugs you will also have water leaking down from furnace. If it is a 80% furnace which will be vented into a chimney then pan needs to be just under a/c
Jun 22, 2010 | Ruud UBHC Air Conditioner
Goodman furnace updraft with A/C on top. Drain tray on A/C (plastic) cracked causing water to leak to floor. On inspection, furnace heat tubes on back show hot spot immediately under the crack in A/C...
You would need to look at the warrenty of the product from the manufacturer of this whole unit. If they were purchased as individual parts then each manufacturer is responsible for their compinents.
However, you must have a warrenty on the product to be able to bear any responsibilty to the manufacturer.
If you do have a warrenty then they should up hold it, and they should also have a solution to the fault. It will be pointless to replace the tray only to have it reoccur again. It seems as though they have missed out putting a insulation of some sort between the heat source which evaporates the water in the tray.
Hope this helps, let me know how you get on.
Thanks
Jason
Jun 04, 2010 | Goodman GMS90703BXA Heater
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Oct 05, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
