Question about Indesit WA 115 Front Load Washer
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
Water wont go into the machine but the wash light stays on. but you here a clink but dosent fill with water or starst cycle help plz
    Champion:
  • 216 Answers
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Posted on Apr 22, 2014
wagdom
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
dazmaraz
  • 67 Answers
SOURCE: indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Posted on Mar 31, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
gary1121
  • 332 Answers
SOURCE: Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
Posted on May 29, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Machine stuck on Cycle and wont cancel
Chances are it is the filter that is blocked, you must remove it completely to check,
Pull ******* the filter to remove it,at worst you may have to break the filter to get it out, it would just mean replacing it with a new one.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Indesit WA 115 Front Load Washer Logo
66 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
