Question about Whirlpool MH7140XF Microwave Oven
Where can I get a parts list for SpacemakerXL JVC1350 oven
Door Handle Availability
Door handle broken
Tony,
There are 11 different models that have this model number you listed, Need more information to answer your question correctly. In black WB15x10020, in almond WB15X336, in white WB15X335. I hope this helps as I looked up all the related models for you. Good Luck
Apr 21, 2014 | Microwave Ovens
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
The lower handle retainer is broke
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If the model number is correct, this is a parts illustration of your oven door:
http://pcappliancerepair.com/model-display.php
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
If you have any questions, please post back with your and let me know. I hope this helps you
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need a new door for this microwave. I have been looking online for hours and can't find just the door. Can anybody give me a website that sells just the door for this micro? Thanks....
The door is available at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
If the model number you listed this question under is correct, the part number for the ENTIRE door is WB56X10585.
Is there a reason for replacing the entire door? You can purchase individual replacement parts if only a single part on the door is broken. The first three sites on the list have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
The most common thing that fails on these doors is the door handle. If only the handle is broken, the door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part numbers for the handle on this model are (2 pieces):
WB15X10119
WB15X10120
May 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken handle on whirlpool model MH7140XF. how do I remove the face of the door with out breaking it?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is available at appliancepartspros.com. There are several part numbers listed, based on the color of your oven, so make sure you order the correct handle. Here is the parts listing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=93877#d93877
If you have any questions, please post back and let me know. I hope this helps you
Apr 13, 2010 | Whirlpool MH7140XF Microwave Oven
Broken handle on over the range microwave
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
Need new handle on door
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 46-114897-3.
Mar 12, 2010 | Sharp R-1750 Microwave Oven
I am trying to replace the door handle. How to I
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke off Microwave oven door can I repair? How can I access mounting screws? Where can I find parts?
If the model number is correct, the part numbers for a door handle replacement is 56001139 and 56001136. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
Dec 29, 2009 | Jenn-Air JMV8000 Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
22 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
