Fagor washing machine 2f 3611 fault f09 - Washing Machines
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Manual for a Fagor Washing Machine FUS 3611 IT
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: fagor, washer dryer , model 2F-3611 flashing
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Posted on Sep 18, 2010
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
Machine stops working and shows F09 what does this mean
Really need the make and model as different manufacturers use the same code to mean different things. Hotpoint/Indesit/Creda F09 on almost all appliances means "Eprom Fault" this is a problem with the main control chip and you will need an engineer to reprogram the main module or swap it out. If it's Bosch, then the good news is F09 means "Heater Fault" which almost certainly means a cheap £20 replacement heating element needs fitting
Sep 19, 2015 | Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
F09
Thanks for using FixYa. Error F09 means heat fault. Please check that the filter is not blocked. The filter should be emptied after every load and/or cleaned once in a week thoroughly. If still the issue is not resolved then you’ll need to get the heat sensor replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Whirlpool LHW0050PQ Front Load Washer
Hotpoint washing machine WF 840 displaying F-09
f09 is a communication fault on the computer board.A suggestion to you would be to unplug unit.Carefully remove and reistall each wire at board
Nov 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint washing machine WF840 which is displaying F-09, do you know the fault
f09 i s a communication problem between mother board and controls.Before replacing board, I would suggest unplugging unit and re-terminating each connecter going to board
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
Jun 12, 2009 | Washing Machines
Mar 17, 2009 | Washing Machines
The washing machine was half way through a cycle and then stopped and displayed F09 fault what does that mean..
this is what is called an Overflow failure error code. you will need to check or replace the pressostat.
Mar 14, 2009 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
