Question about Microsoft Forefront TMG Standard - Processor License
Winzip fails After installing Microsoft Forefront TMG 2010 on 64 bit machine my Winzip64.exe fails. It will start but immediately exits after a popup blinks at me. Uninstalling TMG will fix the problem.
  • 1 more comment
  • Brian Macker
    Brian Macker Apr 22, 2014
    The compatibilty mode didn't help. Starting as administrator didn't help. I uninstalled the newer 64 bit version of Winzip 17.5 and installed an older version of winzip 14.5 that was compatible with ForeFront TMG Client.
  • Anton Trdi? Apr 24, 2014
    too bad it didn't help , well then you can try 32 bit instead od 64
    Also when downloading a program from net , just make sure before ionstalling that you right click on that donloaded file then properties, then on general tab make sure that button "unblock" is pressed and click apply and OK , also makwe sure that you are installing program with administrator privileges
    Champion:
  • 245 Answers
Just right click on the WINZIP.exe , then compatibility tab, click on litlle square of "Run this program in ...", choose one from the menu, then click a little square down "run as administrator", apply , OK, and hopefully that's it !
Posted on Apr 22, 2014
Error 502 secure error
This may be due to software installed on your computer which is preventing access to a particular webpage ( for example if Forefront TMG 2010 is installed), there could be many reasons why the problem exists and usually it is a bad gateway error which can be resolved by googling the error code (copy/paste) and you could also try the college IT dept. to see if they can resolve the issue, hope this helps.
Aug 06, 2017 | Computers & Internet
How to configure forefront gateway 2010
I'd recommend checking out the Forefront Edge Support Center , there is an in-depth user guide for download to get you started on using Forefront Gateway 2010
http://support.microsoft.com/ph/815
May 04, 2013 | Microsoft Forefront TMG Standard -...
Winzip64 for windows 8
You should contact the software manufactures or distributors customer support and they will assist you, otherwise the keys are normally provided with the paperwork for the software when you purchased it.
Apr 17, 2013 | WinZip 12.0 - Windows for PC
Removing of ms forefront in vista
Did you try booting into Safe Mode to remove it?
Nov 17, 2011 | Microsoft Forefront TMG Standard -...
Why will printmaster platinum 2.0 not uninstall
Try using the Windows Installermag-glass_10x10.gif CleanUp Utility. As long as you installed the application using the Windows Installer, this utility will remove all the folders, files, registry keys, and entries from your system and allow you to start over with a clean slate.
Download the Windows Installer CleanUp Utility
Locate and run msicuu2.exe to install the Windows Installer CleanUp Utility.
Locate and launch the Windows Installer CleanUp Utility on the Start menu.
From the Windows Installer CleanUp Utility window, locate the application in the list and click the Remove button.
Once the application has been removed, click the Exit button to close the utility.
You may now reinstall the application or at least have piece of mind that it is gone
This version of the Windows Installer CleanUp Utility works correctly in all 32-bit versions of Microsoft Windows. The 32-bit versions of Microsoft Windows are: :
Microsoft Windows Server 2003
Microsoft Windows XP
Microsoft Windows Millennium Edition
Microsoft Windows 2000
Microsoft Windows NT 4.0 with Service Pack 3 or later
Microsoft Windows 98
Microsoft Windows 95
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Broderbund PrintMaster Platinum 16
Cannot install photoshop elements 6 in vista home edition
There is a problem with the auto-extractor.
Manually extract the files from the downloaded file using Winzip and extract to a new folder. Then run Setup.exe from that folder.
Also, make sure that your Temp folders have been cleared out.
The latest version of WinZip may be downloaded from http://www.winzip.com
Apr 09, 2009 | Adobe Photoshop 7.0 for PC
Install Failed - GetDatFilename() Returned False HP Laserjet 3055
You can find & download the need drivers /program here;
http://h10061.www1.hp.com/ccsearch/search?pname=LaserJet+3055&opname=HP+Photosmart+C4180+All-in-One+Printer&qry=driver&submit.x=10&submit.y=9&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=1141647&search=0
Good Luck!
Rich Lilja
Dec 03, 2008 | HP LaserJet 3055 All-In-One Printer
Error 1603 Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Dec 13, 2007 | HP LaserJet 3055 All-In-One Printer
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Microsoft Forefront TMG Standard - Processor License Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
