Question about Microwave Ovens
Door handle broken
SpacemakerXL Microwave Oven JVM1350
  • Microwave Ovens Master
  • 842 Answers
Tony,
There are 11 different models that have this model number you listed, Need more information to answer your question correctly. In black WB15x10020, in almond WB15X336, in white WB15X335. I hope this helps as I looked up all the related models for you. Good Luck
Posted on Apr 22, 2014
  • Ted H May 05, 2014
    Hello, Tony
    Hello, Tony. I don't really get much of a picture from your statement. It's very obvious that as far as fixing is concerned, you require a new handle. If the unit is "In Warranty", you can likely have the manufacturer supply and install a replacement handle. If not, Gere has the part number you need as soon as you supply the full model number.
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacing a Dacor Microwave Over the Oven Door Handle for Model PMOR30
This Sharp-made Dacor model is equivalent to a Sharp R-1750-series and we have the complete service manual at our site:
http://www.microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
jsrock516
  • 5911 Answers
SOURCE: Microwave broken door handle.
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Posted on Apr 23, 2009
jsrock516
  • 5911 Answers
SOURCE: Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Posted on Jul 16, 2009
  • 10865 Answers
SOURCE: How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Posted on Aug 13, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: replace door handle on mco153uq
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can order parts here.
Posted on Aug 30, 2009
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
My JVM1350 has metal rack inside. How do I use it. I thought you couldn't have any metal inside.
on the inside of micro.. the rack is supported with plastic clips.. this allows stock part metal rack work
May 26, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a GE SpacemakerXL Microwave Oven Model JVM 1350 The fan and the light works, but the microwave is not working and the screen says
There are two possibilities, one of the door switches has malfunctioned, usually caused by food partical buildup, more than likely. or there is an issue with the microprocessor control board, less likely.
Mar 11, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE SpacemakerXL JVM1443 stays on when door is closed
That's almost certainly a failed primary interlock (upper door switch) or its mount is bad.
See our file on info on door switch diagnosis and replacement.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It's broken
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number for a replacement door handle is WB15X10023.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | GE JVM1631 Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
