Question about Frigidaire FRT18HS6JS Stainless Steel Top Freezer Refrigerator
Front load washer will not spin
The machine will not spin, but the door locks and the motor makes a grinding sound as if something is stripped, gears perhaps.
  • Kevin Abrahams
    Kevin Abrahams Apr 21, 2014
    I have changed the door lock and switch assembly. This did nothing to change the original problem.
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Posted on Apr 22, 2014
How do i repair a lg washer that makes a grinding noise when slowing down from spin cycle
It sounds as if the tub bearing on your machine is faulty. To replace this bearing one needs to basically strip down the entire machine.
Not a job for a novice.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
Apr 28, 2014 | LG WM2487H Front Load Washer
My washer wont lock and now it does not spin why
The door has to lock as a safety to allow the machine to run. There is a switch on most locks to tell the machine to power the motor.
I would guess the lock solenoid has failed, or something has happened to the latch for the door.
Sep 16, 2012 | GE WBVH6240F Front Load Washer
Won't spin
We had the same problem. It was the door lock. In addition to the regular lock that prohibits you from opening the door while the machine is running, There is a "wax motor" lock. If this lock fails, it won't do the final spin. Think back to your top load washer, it wouldn't spin if you opened the top. The motor is a universal motor that is used on many front load washers. We found the answer by googling "front loader won't spin" - the wax motor costs $12. The wax motor is inside the door switch control. It opens up with a screw driver, be very gentle.
Oct 11, 2009 | General Electric WSSH300G Front Load...
Washer started grinding during spin, now won't spin at all.
sounds like the motor spun a bearing. Usually this requires a motor replacement. when the bearing breaks down enough, the lube no longer keeps the bearing cool. Then the friction just mounts up and makes alot of noise. after the heat from forcing a broken bearing the motor then overheats and then fails. after letting it cool it might reset itself but only to pop again because the bearing just gets worse until it locks up and becomes heat welded.
so there. I'd say motor replacement since the bearings and motor are all one unit.
Sorry, i hope this helps with the diagnosis
Jun 09, 2009 | Admiral AW22 Top Load Washer
Have a admiral washing machine sounds like something is grinding inside while washing and spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2009 | Admiral AW22 Top Load Washer
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
May 25, 2009 | Washing Machines
Kenmore Elite #20992 can't remove back housing
Comes apart from the front. 2 screws on front of control psnel; flip it up. 2 clips to pry out; also ulplug lid switch. Cabinet lifts up from back and comes right off. Hope this helps!
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Frigidaire FRT18HS6JS Stainless Steel  Top Freezer Refrigerator Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
