Question about NorStar Meridian M7310 Phone
Same problem here. No buttons on the phone work
The only thing that works is when I press shift and ANY other button, it dials to the same extension. Other than that, the buttons on the phone don't work, but i still have a dial tone and can still receieve calls. Any solutions yet?
  • 192 Answers
You have a stuck button.
I would look at the button that the set is calling.
You may have that person as speed dial on the set.
Posted on Jun 20, 2009
OK, I'm nearly there. I've worked out how to label the extension, how to re-do the extension numbers on the phones and change their position. The only problem I have is when I re-do the extension the light...
You're using the buttons on the left side of the phone? What does it read when you press PROGRAM and the programmed button? A TA series does not have "on hook" dialing, you have to press the SP PHONE button or pick up the handset. If the button is programmed properly, the display will read EXT-xxx when you press PROGRAM and the corresponding button on the left side. It will also follow the on-hook/off-hook status of the extension.
Carl
Feb 07, 2011 | Panasonic KX-T7730 Corded Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
I am tring to figure out how to program extensions on our kx-t7737 phone.
A 773x phone has 24 buttons, 12 are lighted and 12 are Feature. If you want to reassign some of the lighted buttons as extension buttons on the phone, you can press PROGRAM 1 + ext no STORE and that will give you a busy indication whenever that extension is off hook.
You can program the right side buttons to speed dial the extensions by just pressing PROGRAM ext no STORE. It will dial the extension when you press it if you have intercom dial tone.
How the button behaves is dependent on which system the phone is attached to. In a TA, you have to start with dial tone on the intercom. In a TAW/TDA you don't.
Carl
Sep 28, 2009 | Panasonic KX-T7633 Corded Phone
How can i program the extensions directly on the phone, without having to dial them.
It depends on how many lighted spare buttons you have. in a TA type system, you press PROGRAM, press a spare button, and dial 1+ the extension you want to dial and STORE. If you just want a speed dial to an extension, you can program them on the right side by PROGRAM, button, ext, and STORE.
With the lights, you can monitor the progress of the extension users. It's called DSS (direct station selection) in the manuals.
If you have a TA or lower system, you have to pick up the handset or press SP PHONE and make sure you're on the intercom, then press the buttons. In a TAW or greater, you can just press the button and pick up the handset or the SP PHONE will go on automatically.
Carl
Sep 17, 2009 | Panasonic KX-T7730 Corded Phone
AVAYA Phone System: Lucent Partner Mail
press feat 00. touch btn to program dial feat14. this is now a voice mail transfer button. to program an ext button, touch btn to program, press left intercom dial 2 digit extension. Can you dial 777 and get voice mail?
Aug 26, 2009 | Lucent PARTNER18 Corded Phone
Meridian Norstar M7310 -- Phone's buttons seem disabled.
Sounds like a stuck button!
Look for the button that is depressed... or the button that has that person that the set is always calling and remove that button with a key/ small knife/ screwdriver or something.
When you take this button off the set, I bet that your set will start working again.
Clean that button, maybe there is something spilled on it.
Good Luck.
Jun 21, 2009 | NorStar Meridian M7310 Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Dial code features for setting up extions buttons.
Look around for a little red book about 4x6 inches. It has all of the feature access codes for a partner phone.
Feature buttons for intercom are programmed by FEAT 00
Press button to program
Press Intercom and dial ext
End by pressing FEAT 00
Carl
Sep 05, 2008 | Lucent PARTNER18 Corded Phone
Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Aug 20, 2008 | Panasonic KX-T7433B Corded Phone
I can't get the voicemail button to work
You are describing two different things. The "speaker 43" is the default code for Busy/No Anser Set. The correct syntax should be Speaker - 43 - 399 - Speaker. That should set CFWD B/NA to VM. Next, if you have a button programmed to call VM, it is probably a speed-dial or one-touch button. It would have to be programmed to dial 399. If that is not working, try calling VM (399) and make sure you can get into the box that way. If that works, but the button does not, press the Feature Key and the button for VM. It should display what is programmed for that button. If it needs to be changed to call VM, the syntax is: Feature - Redial - the button to program - "1" - "399" - Feature.
Feb 07, 2008 | NEC DTU 8D-2 Corded Phone
NorStar Meridian M7310 Phone Logo
202 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
