Question about Dell A940 All-In-One InkJet Printer
Color ink catridge
I have just bought a color ink catridge after a few uses I know longer can print color I have checked the printer and it is reading that I still have color ink to use. I have done a printer clean. Still nothing and when I take the cartridge out I can see the ink coming out. What could be the problem?
  • 1,601 Answers
Re: Color ink catridge
0 characters
3 Points
I just bought 2 new catridges (black & color) but the color ink dosen't print.
I'm not familiar with Lexmark but I think your printer is set only to print on black cartridge (black only option) There's something wrong with the settings. Check the settings, look for the color options.
May 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Prints are green
it can be due to ,, color catridge contains only green,, since the other colors,, are been used for prior printings,, and the green ink is left in the catridge,, you can check.. make use settings to print in gray scale,, dont use color.. then it should be fine.. but the color cartridge to be replaced
Sep 27, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
C4200 Not printing black ink, which is new
Its purely your CATRIDGE please open up your printer and check for the two small black colored that you can easily identify the B/W if its lighter in weight compared to that of coloured need to refill it or buy a new catridge......THIS is the only solution to this problem..
Jun 22, 2009 | HP Photosmart C4180 All-In-One InkJet...
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Ink, copying and printing problems
canon MP 150 Series printer usB001
The waste ink absorber is full
May 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Dell A940 All-In-One InkJet Printer Logo
24 people viewed this question
Top Dell Printers & Copiers Experts
Prashant  Sharma
Prashant Sharma
Rick Johnson
Rick Johnson
Level 1 Expert
Are you a Dell Printer and Copier Expert? Answer questions, earn points and help others
