Question about True TSSU-48-12 Refrigerator Commercial
REPLACE HINGE REPLACE RIGHT TOP HINGE
  • KRIS
    KRIS Apr 26, 2014
    Thanks Randy, I got it. yes it was easy. TY
  • 67 Answers
This hinge is a cartridge and the bottom hinge has to be removed to replace it, then you just unscrew the cartridge and change it out, it's pretty simple.
Posted on Apr 25, 2014
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
How to replace the cabin air filter in a 2000 toyota avalon xls
lower the glove box and its forward of that, should be a plastic panel to remove.
Sep 23, 2009 | 2004 Toyota Avalon
How do i replace the gasket on a top freezer refrigator?
Hi, first you will have to remove top freezer door, remove plastic cover from hinge, at left or right, above door, remove top hinge, tilt door slightly forward and lift off, be careful with spacers between door and hinge, you have to put back spacer between door and hinge to get proper alignment. put door on flat surface, lift rubber and check underneat, you will see screws or plastic clips, if there's screw, make like 3 or 4 turns with screwdriver, dont completely remove screw, if you don't have, don't know what type of ref. you got, remove old door gasket, replace new one, and put it back on. good luck.
Aug 07, 2009 | Refrigerators
How do i change which side the door opens
I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
Jul 10, 2009 | Bosch Classixx KSR32623 Refrigerator
Side side door noise(fridge side door)
you need the lower hinge and cam kit. remeve the top hinge then lift the door off the hinge and replace the hinge and the cam on the door.
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I replace the LCD screen hinge on my IBM T41?
I'm sure you could get these hinges from IBM, but no idea as to their cost. They are available on e-bay for $8-$35 (depending on whether you want 1 or a set) plus $8-$10 shipping.
As far as replacement. You will have to remove the Top cover assembly from the base of the PC. If you need help with that, just let me know and I'll talk you through that.
To replace the hinge, you will have to disassemble the Top cover assembly.The screws that you will need to remove are covered by small black adhesive covers. There are 3 round ones along the bottom of the bezel, 2 square ones up at the top of the bezel (to the left of the white LED keyboard light, and 6 (trapezoidal shaped) on the outside of the cover (3 on each side). Carefully remove those covers and the screws that are under the covers. Keep track of where the screws should go back in.
The actual bezel is held into the top cover with some internal snaps. Start at one of the corners, run a knife blade along the seam (between the cover and bezel) and you will hear each fastener "snap" as you slide the blade past it. Once the bezel is loose, lift it off of the LDC screen. There is one additional screw that is located up in the upper right hand corner. That one will need to be removed, also.
Gently lift the right hand side of the LCD assembly a couple of inches and place something of appropriate size to hold it in the raised position. You will see 2 additional screws that hold the hinge to the LCD assemble. Remove those and the old hinge will come right off.
Position the new hinge and replace the two screws that you had just removed. Reverse the removal sequence to reassemble the display.
Before you start snapping the bezel back into place, check to make sure that the two cover catches (those hook things, up at the top of the LCD assembly) are both operational. The link going to the left hand one tends to easily fall off.
This procedure should take in the neighborhood of 45 minutes to an hour.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 15, 2007 | IBM ThinkPad T41 Notebook
True TSSU-48-12 Refrigerator Commercial Logo
51 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
