Question about Kenmore 43142 Front Load Washer
Washer trying to turn on by itself; lighting up and peeping.
Model 417.48102701 November 2007 Serial XC 74903045 Lights turing on and beeping even when in the action of washing as well as when door open and no activity. No associated with storms or power surges.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Oasis Washer
The problem is the User Interface board behind the control panel. This is a noted problem that often occurs with this model washer. The only option, I hate to say (unless you want to listen to the washer beep all the time) is to replace the board.
The part(s) you need are available at searspartsdirect.com. Simply type in your model number and look under the "Control Panel Parts" heading for item number 7 (User Interface - part #8564393). You may also consider item number 12 (User Interface Harness - part #3407184) to rule out the possibility of a bad wiring harness. You can try to do end to end continuity checks before considering a replacement just to be sure. The contacts are sometimes difficult to get to with a multimeter, though.
This is a fairly simple repair to accomplish on your own. Just follow these steps:
1. UNPLUG the washer.
2. Remove the three screws in the back of the console.
3. With the screws loosened, the console will come of by lifting from the back first. Use care not to damage the small wire harness under the console.
4. Remove the wire harness from the User Interface board and remove the knob (by pulling) from the front panel. Lay the entire control panel face down on a soft surface (like a stack of towels).
5. Carefully remove the white plastic cover plate that is installed over the control board.
6. Once the cover is removed, carefully remove the old interface board by prying gently on the series of tabs around the perimeter of the board. There may also be some mounting screws to remove as well.
7. With the old board removed, carefully install the new board by inserting the control knob shaft through the hole first. Then, gently snap the board in place, making sure all the tabs around the perimeter of the board are in place. Reinstall any small mounting screws. NOTE: Do not handle the surface of the board with your hands. Handle the edges only, to avoid electrostatic discharge from your body causing damage to the board.
8. Reinstall the protective plastic white cover over the interface board.
9. Flip the console upright and reinstall the wiring harness and control knob (The knob only goes on one way).
10. Carefully insert the console in the front grooves on top of the washer, first. Then lower the back and reinstall the screws.
The repair is pretty straight forward. However, if you have questions, please post back and let me know. I hope this helps you.
PS I tried to find parts for this washer at others websites, but could not find a listing for it.
Posted on Jul 19, 2008
SOURCE: Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
Posted on Jan 26, 2008
  • 1294 Answers
SOURCE: Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
Posted on May 30, 2008
SOURCE: kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Posted on Jan 10, 2009
SOURCE: front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Posted on Jan 24, 2009
This TV has Model number 2404141 serial number H466DD2D7 also ATC 106 and service # 2404141T This is a relative's set. When turned on, either with the remote or button on the cabinet, it acts as...
id suspect power supply boad is faulty......
if you can use a soldering iron.............
replace the caps on the board..........or search ebay for a replacement board........
cheers
May 02, 2011 | RCA Televison & Video
How old is my maytag neptune washer. model # mah3000awa serial # 32156767uy
The two letters at the end the serial number indicates the year and month, respectively, when the machine was manufactured. Refer to the table below.
In the case of your machine, the letters are U(1987/2011) and Y(November). The machine was therefore manufactured on November 1987.
Jan 16, 2011 | Maytag Washing Machines
Hi my Pride Washer model MW 512 gives long beeps and 1st longwash n 7th after the rinse orange light flashing as well, As it starts to fill the washer it stops n starts with continuos beeps even though i...
Hi just read your posting.Now you mentioned in your posting that the lights that are on when the machine is beeping are 1and 7.This is on the row of 8 lights and you started from left to right.Is this correct? If it is correct then the fault you have on your machine is called SINGLE ROTOR POSITION SENSOR ERROR.This means that the rotor sensor which is attached to your motor is faulty or your control module is faulty.Please reply with confirmation on the lights that are on when the machine is beeping and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi there, my Samsung WB500 camera can not get it's lens closed. It stands open all the time and is doing nothing. When I turn the power on, it 3 times makes a hard noise 'peep peep peep', no display and...
This is a common problem with cameras. They can get bumped when the lens is out, and that can jam the gear assembly, or break a gear. I could run down all the things you can try to free it up, but there is a better web page that deals with issues like this. The page deals with error messages for the lens, but the beeping you hear is an error message, also. Follow their suggestions to try to free the lens up- maybe you'll get lucky. They say that, in about 50% of the cases, it can be fixed by trying their suggestions. Here's the site:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If nothing works, make sure you get an estimate before getting the camera repaired. Sometimes the cost of repair justifies going ahead and purchasing a new camera, on sale, and is often less expensive than having it repaired. Good luck! Hope you get it working again!
May 18, 2010 | Cameras
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Control Panel Comes On By Itself
Mine does this if there is the tiniest power interruption. Even if the lights only barely flash and nothing else happens in the whole house, the washer lights up. I just cancel mine out. It is not going to start running, and I don;t think there is a solution to this annoying little glitch.
Jul 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 43142 Front Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
