Question about managemylife.com
Kenmore front loading washing machine model #417.44052400
Washing machine fills with water for approx 15 secs then stops
  • Pete Salisbury
    Pete Salisbury Apr 23, 2014
    Check the water inlet hose screen my be plug
  • Steve D May 02, 2014
    Hi, with modern washingmachines there are level sensors at various places to trigger operations in the cycle. If you access the back of the machine you should see them basically they get blocked up and therfore send a false level signal to the controller. I am not familiar with that particular machine. If you cant access them my only suggestion would be to put a good dose of something like calgon or vical and let the machine run on a long wash to try to clean out the sensor holes. I hope this is of some use, good luck. Kind regards Steve
  • 381 Answers
I don't know exactly what the error code is to help give an answer that is specific to you. Please go to this link to view an excellent video to help explain to you how the front load machine works. You can also order new parts through them also!
The link is; http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Good Luck!
Rich Lilja
Washing Machine Repair Help
Posted on Apr 22, 2014
Kenmore washer - model #22912 will not spin. It will fill, rinse, and soak...but it will not spin.Water remains.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Kenmore Washing Machines
My washer is tumbling damped clothes but seems not to be acutally washing my clothes. whats going on? Just a bit water comes out for about 2 sec then stops but no water is actually in the drum just...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Apr 09, 2011 | Kenmore Front Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Washer not is use fills with water? why?
It is kind of the opposite of these tips...instead of the dirt stopping off the water, the dirt is stuck in the valve and holding it open...
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 16, 2010 | Kenmore 44102 Front Load Washer
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
May 03, 2010 | Kenmore Washing Machines
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Front Load 3.5 cu ft Washing Machine, NO SPIN CYCLE
is it in a diagnostic mode? unplug from wall for 15 sec or so and try again.
May 15, 2008 | Kenmore Elite 45986 Front Load Washer
managemylife.com Logo
77 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
