Damage parts need star base 61-base5607M & 5 casters 61-casta
Any user manual/documentation for an oil-filled heater, Italian, name on nameplate Omas? Today I purchased a used one.
luckily most
caster wheels can be interchanged or retro fitted to any oil heater
take one of the castors with you
just takes time to find 4 that will suit your heaters fitment
big hardware stores or a known caster wheel seller ,ebay
heater oil is heater oil so that can be sourced easily
a few older style Omas oil heaters for sale in New Zealand
newer models from amazon
cant find its user manual online
or a parts supplier that will carry Omas parts
Oct 13, 2016 | Heating & Cooling
Hi, kenmore model 116.25812508 how does the single front wheel assembly come off. It needs to be replaced with part KC95CBZTZV06.
I found this on the Sears website, I'm just copying it. There are 2 possible solutions here.
It can be difficult disassembling parts on your own vacuum. I have taken some time to research your question here on the Manage My Life website and I noticed that someone else had asked a similar question with a posted response from an expert. I attached the link below if you are interested in viewing. I hope the link that I provided is helpful. Have a great day. by afritz afritz Earned 1,558 community points in Click">Upright Vacuums May 26th, 2011
I understand the issue you are having with removing the swivel wheel assembly.
From your reply I see that you have the other style design which is quite similar but with out the locking tabs exposed.
I don't always relate this way of removing the swivel wheel because people are afraid that they will damage the base of the vacuum. Use a large flat bladed screwdriver and get it up under the swivel plate and pry the wheel assembly off. The manufacturing engineers were of the opinion that this part would not break so I think when they designed the part they did not have in mind that someone may replace it. This makes it difficult to replace.
When installing the new one you will need to press it into the hole so it will snap into place.
Let me know how it goes.
Sam A. by Sam A Earned 6,102 community points in Click">Upright Vacuums May 27th, 2011
Thank you for your question.
I can understand wanting to know how to replace the swivel caster on the vacuum base assembly.
To replace the caster you will need to use a pair of needle nose pliers and pinch back the clips and then drive the caster from the base.
I suggest that you support the base between two short pieces of wood so the caster can be pressed out the bottom without touching the support.
As you can see by the new one it will snap into place in the hole of the base after you remove the old one.
I hope these instructions will help.
Thank you for using Manage My Life. by Sam A Earned 6,102 community points in Click">Upright Vacuums May 27th, 2011
Jul 19, 2016 | Kenmore Vacuums
I am putting it on a platform so it will drain into my sink trap. how do i take off the casters so it will sit with stability?
Thank you for your post, Lee!
From the information you have provided you with like to take the caster wheels off in order to allow stability to your Frigidaire dehumidifier. We would not recommend removing the caster wheels. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Aug 01, 2015 | Frigidaire FAD704DWD 70 Pint/Day Energy...
2007 V Star 1300 will not pick up speed after 65mph
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Yamaha XVS1300A 2007 Service Manual
OEM parts for Yamaha
Yamaha midnight star XVS1300A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 18, 2014 | 2007 Yamaha V Star 1300 Base
Yamaha v star wiring diagram
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha Star 1100 wiring diagram Google Search
Electronics Star 1100 Wiki Knowledge Base
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Apr 13, 2014 | 2005 Yamaha V Star 1100 Classic
My 1700 road star is flooding, and won't idle, sat for awhile only 8000 kms on it
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Re bike stalling Road Star Forum Yamaha Road Star
Bike Mechanic Help
http://www.rswarriordocs.com/manuals/WarriorServiceManual-WO3646.pdf
Yamaha XV17ATMV Road Star Owner Manual
Aug 03, 2013 | 2005 Yamaha Road Star Silverado
I need additional paper trays, mine only has two.
Yes.
There are 3 Bases that this system will take.
1. Plain Stand (this is the one you have)
2. PB3070 (This will give you an additional 500 sheets and you will
need to add a Caster Base with this option.
3. PB3030 (This will give you 2 addional 500 sheet trays) No Caster
Base needed
Mar 01, 2013 | Gestetner DSc525 All-In-One Laser Printer
Please help me as I purchased a Rubbermaid Home & Office Cart model 4401 and need to know which are the correct caster wheels for it.Is it the 5 in. 2 rigid and the 2 swivel with the 4 holes or is it...
I see the description says, "500-lb. capacity model has ... 5in dia. casters for extra stability. .... Four nonmarking casters two swivel."
As to screw size, I can't estimate without seeing it, so I would suggest going to a place that sells it.
But you could also ask Rubbermaid:
"For replacement parts, please contact Rubbermaid Consumer Service by calling 1-888-895-2110 Monday through Friday, 8:30 am to 5:00 pm ET or by email using our contact form."
http://www.rubbermaid.com/supportCenter/Pages/ReplacementParts.aspx
Mar 12, 2011 | Garden
Headlight does not work
Hi, Rvheusen if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Lighting Star 1100 Wiki Knowledge Base
http://www.starbikeforums.com/forums/49-v-star/8800-headlight-fuse-location-1999-vstar-1100-custom.html
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
May 09, 2010 | 1999 Yamaha V Star 1100 Custom
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
