Question about Apple iPod touch
What happens if the earth stops spinning - Apple iPod touch
    New Friend:
  • 4 Answers
It would not be good
Posted on Apr 26, 2014
HOW FAST PRE MILLE DOSE THE EARTH SPIN
1,040 mph
An object on the Earth's equator travels once around the Earth's circumference. This is about 24,901 miles (40,075 kilometres) per day. To calculate speed, Mr Kadish divided that distance by 23hr, 56m, 4s to reach the figure of 1,040 mph.28 Jan 2014
How fast are YOU spinning on Earth's axis? ' Daily Mail Online
www.dailymail.co.uk/sciencetech/article.../How-fast-YOU-spinning-Earths-axis.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=how%20fast%20does%20the%20earth%20spin
Dec 01, 2016 | Cars & Trucks
Stops rotating and shows warning triangle. Batteries good ,not windy
Stops rotating? You mean the engine stops spinning/turning over?
Check the battery earth lead - the black lead - where it fits the battery and also where it connects to the bodywork. remove and clean all terminals and make sure they are TIGHT.
A 'bad earth' can cause slow crank-over. Bear in mind that if you disconnect your battery you may also lose your radio code
Feb 25, 2016 | Cars & Trucks
Keypad stop working when liftgate was changed
no experiance on this vehicle but on amny a car i have encountered a problem similar and that is that in the tailgate loom that runs through the rubber tube into the tailgate from the body is a earth wire and for some strange reason if this earth wire is damaged then often weird things happen ,like a ford galaxy which is a VW here in europe then the main beam doesnt work ,on another renault model the car will not start ,the immobilisor light stays .Now dont ask me to explain this as obviously this isnt right but if a earth or ground point corrodes up the its grounding out down a different cable that might just happen to be on the same earth fixing point ?? but this sort of thing i have and do get all the time
Feb 23, 2016 | Chevrolet Cars & Trucks
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
When i use the indicators the neutral light or brake light flash in time with indicators what is wrong
it sounds like there is a bad ground (earth) someplace in the vehicle .
Sep 14, 2015 | Cars & Trucks
I have a 2004 Tahoe, everything works except the rear pasenger side tail light, and yes i checked the bulb.
have you checked the earth ?? try running your own earth (ground ) and see what happens ,if the ground or earth wire is faulty then the indicator will come on when teh stop light is applied ,but as this is an american vehicle where the stop light is the indicator as well it might not show ,our europeon vehicles use a separate indicator light which is yellow so thats when you notice it as the indicator and stop light all come on dimly because they are different circuits
Mar 18, 2011 | 2004 Chevrolet Tahoe
Compaq c300/c500 power on button, fan starts then fast blinking
what compaq use real models numbers clearly.
panel sounds desktop like.
ever heard of PC repair shop.
we have
1.1 Bilion Computers. on earth now.
guess what , vast numbers of shops with certified technicians
every where, on earth, were there are people.
is the screen dead, ? no text ever, and BIOS dead.
if a desktop the PSU is dead.
Jun 25, 2017 | Compaq Computers & Internet
Matsui mwm145w goes straight into a spin cycle
Try to move the timer to a different postion if it still does the same thing turn the timer one full turn and try turning it on again if it still does it you have a bad timer, as for the bounceing that could be casue the leg stops need to be adjusted so machine is level, You may have a bad drum roller as well.
Aug 20, 2009 | Washing Machines
No hazard lights
Check the hazard switch and the connector to hazard switch see if u have the power and earth to hazard switch if there is power and earth to switch then replace ur hazard switch its faulty but if there is no power and earth to switch then it has whirring problem
Jun 16, 2009 | 1997 Mitsubishi Mirage
Crashes when i start EE AoC
DO not worry i have vista but it works for me. you may need more R.A.M or free space or if your not an administrator ask the administrator to allow empire earth AOC cos i had that prob but i fixed it.
Jan 16, 2009 | Empire Earth Expansion: The Art of...
Apple iPod touch Logo
16 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
