Question about Kodak EasyShare C913 Digital Camera
How to get Sand out of my Camera?
Ok, one time, me and my little sister went to the beach to play around. Then, we decided to make a movie about a sand man. But during filming, I got sand in my camera and now, one of the lens protectors won't close and the the part that goes in and out sometimes jams. So can I open my camera? I think I can because there are screws that hold the camera. So what should I do. Do I open it, or not?
    New Friend:
  • 30 Answers
You should not open it. You should take it to a professional for repair. Sand is scratchy, the more you mess with it, the more scratches.
Posted on Aug 11, 2017
Bogdan
  • 198 Answers
SOURCE: Need to clean
Hello sticky, This is a lens assembly mechanism problem. It is a delicate part of any camera. Altrought some people may sugest you to use a compressed air spray to remove the sand in the inner lens by blowing it out i don't recomand that because sand particles can be pushed out even further in the lens and could be causing even more damage. The lens assembly is composed of several servomotors, coils, some sensors and the actual lens. It does the following jobs: it extends the lens back and forth achieves focus by moving the lens zooms the lens by rotating them in the same time as the whole objective is moved back and forth Each of these operations is controlled by some servomotors who actually move these parts and are also connected to some sensors that pass the readings back to a main processing unit. When you open the camera this processing unit will check to see if the lens assembly is able to do all of these 3 things. Failure to comply with even one of them will result in some error (lens error) or simply having the camera not opening. "Lens error" or "zoom error" is a generic message, doesn't mean that the lens itself are damaged, could be the connector to their servomotors, sensor failure, some coils that are out of position and things like that. In your case the sand particles are preventing the servomotors to properly align the lens. They are all related to the lens assembly. Because this is a VERY fragile part of any camera I don't suggest you to try a DiY repair because you can damage the lens even further. Even service centers have problems repairing this, most time it is done under a microscope and some times it simply can't be fixed. This problems occur most of the time in corelation with the camera being dropped or received some shocks but even some small particles or sand in your case, can cause this problems as you can see. I would recomand you to go to a service center. Try not the big ones that represent large corporations (because they are expensive), instead look for a smaller one. Tell them you have a lens assembly problem, also tell them that it's caused by sand, ask them to make you a diagnostic and then ask for a cost estimate BEFORE they actually repair the camera. If the lens assembly is damaged beyound repair it will need to be changed as a whole, including all connectors, CCD sensor and so on. This could cost from $70 - $200 excluding labor parts that can be about $100. Therefore you should ask them a cost estimate. I'm sorry for not being able to provide a DiY solution but like i've said, i don't recomand one. In the future try not to expose the camera to any shock, sand or excesive dust and temperature variation. These are all known to give a great deal of trouble with digital cameras. If you need more info please post back. Good luck.
Posted on Apr 04, 2007
  • 479 Answers
SOURCE: I got sand in my camera
send to repair... a camera repair person should be able to clean and get your lens back on track
Posted on Sep 03, 2008
arclight1217
  • 208 Answers
SOURCE: Digital camera got dropped into
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Posted on Nov 04, 2008
leecom72
  • 4806 Answers
SOURCE: is the camera fixable if it has sand in it?
Hi there.
If you have sand in the lens then chances are that some moisture has got into it to.
This means you have to disassemble the camera to get it working again and takes plenty of patience as its not for the faint hearted.
If you don't want to do it yourself you can take it to a service center for repair.
Thanks for choosing FixYa!!
Posted on May 28, 2009
  • 8 Answers
SOURCE: I dropped my mx1063 in the sand at the beach. I
This is not a user solvable problem. One thing that should not be done is to turn on the camera when it has been dropped in dirt, sand or water. This will, in your case, grind the dirt around and parts try to move and contaminate additional parts of the camera. It's only worse if water is involved as this will likely cause shorts in electrical areas.
Take the camera to a repair shop and get their opinion on whether it is fixable and if so what they estimate the cost to be. Sometimes it's cheaper to buy a new or used camera.
Posted on Jul 22, 2009
Beach dust dropped in beach.
Cameras and beaches don\'t do well at all. The most important thing is to remove as much sand as possible without scratching any part of the camera. I\'d suggest to not wipe it at all, but take it home and try to vacuum the sand and dust off. It can get wedged in the drive mechanism for the lens focusing and will stop the camera from going through its normal initialization cycle. Check around the edges of where the lens moves in and out for sand, and try to suck it out.
Nov 17, 2013 | Canon PowerShot SD1100 IS Digital Camera
Is it worth buying beach toys for my nieces and nephews or will they just be happy to play in the sand?
When kids don't have anything to play with, they make do with what they have, but these days there are some brilliant sand toys around that you can use on the beach or in the sand pit. You can get everything from sand toys that help you haul, trawl and build, to toys for throwing games etc. I'd say it's well worth investing and your family will be very grateful.
Jan 10, 2013 | Toys
I went to the beach and I put my camera in my pocket, and sand got into my lenses of the camera.
Hi there Dash,
What happens was that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. So here is what you do. With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. If the above solution does not work, you might need to blow a canned air around the sides of the lens of your camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Jan 30, 2011 | Nikon Coolpix L11 Digital Camera
Problem with M340 Kodak easy share digital camera..( automaticall
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera lens won't come out and it beeps three times.
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 15, 2009 | Samsung S860 Digital Camera
Lens error was at beach no sand but yet when turned on it says lens error
Anyone who has ever been near the beach knows that as soon as you are within 100ft of the sand you will feel sand in between your toes even with your sneakers and socks on. That's because sand is in the air and contaminates everything. Therefore, if you value your camera, mp3 player, radio, cellular phone PDA, or laptop computer, DO NOT TAKE IT anywhere near the beach. Solution: use an air compressor. Blow air & dust through the hose first. Use clean air to blow out extended lens area. Open and close lens and blow out several times. Firmly jolt the camera into the palm of your hand to dislodge the dirt particle. Use more air. You may notice sratches on the side of the lens cylinder that were created by the particles of sand. 99% pure isopropyl alcohol (91% if you're in a pinch is available at any drug store) can also be used on a Q tip and swabbed around the lens barrel cylinder. Make sure you use a few CLEAN Q tips on the lens. Now go buy a disposible camera and $10 mp3 player for the beach and leave the $200+ camera and IPOD at home or at the hotel room. Now you'll surely have a wonderful time at the beach.
Jul 28, 2009 | GE A730 Digital Camera
Power shuts off on its own
Yes the beach, two of camera worst enemies, water and sand. The camera should be taken apart to check for sand and water damage. Camera that are even exposed to air around salt water will develop problems.
Jul 02, 2009 | Kodak EasyShare M1033 - black Digital...
Lens will not extend
Hi:
You need to clean around the lense first. Blow high pressure air spray and get the most sand out of the lense you possibly can.
If it did not open 100%, try to pull it out NOT too hard. If the lese goes up and down and turns you should follow the lense while pulling it out.
When it is 100% out, (the way normally opens) Clean around the lense more.
Turn you camera on and off a few times. It should be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 20, 2009 | Konica Minolta DiMAGE G500 Digital Camera
Sony Cyber-Shot Lens!
I really don't know a lot about this stuff..but if I were you I'd go and have it professionally cleaned right away. You don't want sand in their messing up the camera.
Jun 19, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Kodak EasyShare C913 Digital Camera Logo
2,794 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
