Question about Acer Computers & Internet
Trys to start but doesnt
The light flashes and it beeps and the fan sound as if its going to start but just stops again
  • 1,087 Answers
The bios keeps track of all mechanical s pre-boot and post-boot. Beeps most generally mean a bad stick of ram or the ram is not seated firmly in the slot. The other issues are bad CPU or the CPU fan has stopped and the bios shuts the pc down in either case.
Posted on Mar 31, 2015
  • 20 Answers
SOURCE: acer aspire t135 desktop doesnt start
Howdy...
I would shed the loads and measure the power supply (pinouts available everywhere on net) what that means is disconnect the drives and I/O cables to them (at the MOBO). Remove any recently added cards or ram . You should be able to see video and/or beeps if voltages are reasonable . A spare power supply would be handy .
Slowly add things until failure shows or if MOBO seems at fault ,try your stuff in another PC . There has been rash of swollen/leaking caps 'round these parts due to bad power supplies or bad caps . Bad power supplies can destroy the MOBO . Changing these caps will often resurect a MOBO
but this is not for the inexperienced desolderer as these
boards are multilayer .
Good luck
Hugh I
Posted on Jan 31, 2008
  • 164 Answers
SOURCE: when pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Posted on Mar 09, 2010
  • 289 Answers
SOURCE: when i start my pc it starts then turns off
The HDD could be faulty, The power supply could be bad, the mobo could be going to be bad. Mostly probably could be that the hard drive thinks there is a device change.
Posted on Jun 16, 2010
Satheeshd
  • 77 Answers
SOURCE: Hello,
This issue might happen due to RAM.
To resolve this issue:
Turn of the power supply for your desktop.
Please remove the side case on your tower(CPU).
find the RAM slot and remove the RAM from the Slot.
Clean the RAM terminals with the help of cloth or Eraser.
After cleaning place the RAM on RAM slot.
Now try to turn ON the PC desktop. If it is working thats fine or else you need to replace another RAM to check.
Please refer the below figure to find the RAM Slot and the lock to remove the RAM.
Posted on Jan 21, 2011
  • 961 Answers
SOURCE: press start button, fan trys
If your fan is trying to start up but won't, your system is going to give you a warning and most likely shut down. Make sure you have good connection for fan power and that it is clean and can turn freely. You may want to cosider replacing the fan.
Posted on Apr 09, 2011
My tv turned itself off and not even the stand by light was on. i unplugged it and changed the lamp. when i plugged it back in the stand by light came on but the tv doesnt. under the stand by light is a...
when you turn TV on, watch to see if the Lamp Fan is running,if it stops when Lamp trys to light then set will not come on.which then means Lamp Fan is defective.
Nov 24, 2010 | LG RU-52SZ51D 52" Rear Projection...
My ADP 8342 continually sounds 10 beeps, stops the...
Refer the user guide for the error message meaning. Contact service provider.
Before that make sure that the water supply to the inlet is having free flow.
May 21, 2010 | Dishwashers
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
When pluged into outlet fans spins and doesnt stop, wont boot
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Red light indecator keeps flashing red
Flashing red is a fan fail . It is probly blinking like 3 short and 1 long blink. If so then most likely your tv needs to have a new dmd fan installed.
Also once that tv detects a stopped fan it must be unpluugged from the wall outlet and plugged back in to get it to even try to turn on again. Sometimes fans will kinda work after a few trys or when the tv gets moved around.
Oct 11, 2009 | Mitsubishi WD-52327 52" Rear Projection...
The sd card reader in hp compaq nx6125 is not working
dear it is damaged...please replace....when this message show then memory card is damaged and not readable or not writeable.
Apr 23, 2009 | HP Compaq Business nx6125 Notebook
Boot everytime
POBLEM WITH THE MOTHERBOARD...SORRY...
IF IT IS WITHIN WARRANTY TRY GET IT DONE THRU VENDOR IT WILL SAVE MONEY
May 22, 2008 | HP Compaq nx6125 Notebook
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
