Question about Maytag MFT2771WEM
Water/ice in the bottom of freezer
We continue to find ice build up in the bottom of the freezer. What is wrong and where is the water coming from?
    Habit-Forming:
  • 119 Answers
Matt, you have a frozen condensate drain tube. Now, the easiest way to solve this is to thaw the drain line. Remove everything from the freezer, drawers too. Now you can either leave the unit unplugged over night or hurry up the drain thaw by using a hair dryer ( heat gun is too hot ) and aiming it at the center of the back panel in the freezer, center, bottom just at the bottom of the metal back panel. This is going to take some time, 2+ hours until it is totally thawed. To check, using a baster, squeeze some hot water into the drain trough under and behind the pack panel, it should drain out, if not, add more heat and time. Once this drain tube is completely thawed and flowing, order and install the following drain tube kit.
Drain Pipe W10619951
This will solve this common problem on Whirlpool/Maytag bottom freezer refrigerators.
Posted on Apr 21, 2014
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
larryyb
  • 291 Answers
SOURCE: ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Posted on Jan 14, 2009
SOURCE: Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Posted on Feb 05, 2010
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
LG LFC21760ST: In freezer area floor, there is ice build-up. Water is leaking from the back wall where two horizontal openings are (near the center). We've turned off the water for the ice maker but this...
If you shut off the water to the ice maker, the only other cause is a plugged drain hole. Somewhere around the bottom of your freezer there will be a small hole that allows moisture to drain out of the freezer and into a catch pan under the refrigerator. If this hole is plugged with ice then the water has no where to drain but out the door of the freezer and puddling on your floor. The water you see dripping is condensation that has built up in the freezer itself.
To fix this problem, you need to dislodge/remove the ice from the bottom of the freezer and the hole. I have had the best luck using warm water with a turkey baster. Another alternative would be an ice pick or any type of utensil that can be safely used to dislodge the ice from the whole and the bottom of the freezer. I prefer the water method because it is the safest. Ideally what you want to do is force warm water in small quantites down the hole. This will melt the ice and reopen the drainage. You then need to remove any ice around the bottom of the freezer using warm water. When done make sure to dry the bottom of the freezer.
May 05, 2011 | Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Our 8 year old refrigerator has recently begun making a continuous tapping sound. The sounds stops when you open the bottom freezer door.
the compresor fan is might make that sound or the fan in your freezer is tuching something like build up ice... see if you can reach it and clean it.
Jan 01, 2010 | Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Maytag MFT2771WEM Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
