Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward pool heater. It's about 5 years
I have a Hayward pool heater. It's about 5 years old. This season it started working fine and then all of a sudden the temperature display simply states 126 and the heater does not turn on. When I lower or raise the heat gauge, the display shows the set temperature for a moment, for instance 85 degrees and then quickly returns to 126. Is there a reset or restart process I need to start? How do I check if the pilot light is lit and how do I start it? With a BBQ lighter? A match? Right now I've powered it off.
  • 139 Answers
Would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Posted on Jun 20, 2009
I have a Jandy XL 250 the exchanger was sooted up the burners were disfigured from overheating so ive cleaned the heat exchanger replaced the burners and the front panel still gets very hot after about 20...
flame should be blue, this sounds like a natural gas unit (orfice) running on LP. Lp is burns hotter than nat. and will burn orange. and use huge amounts of fuel.
Aug 10, 2013 | Hayward 250kbtu Ng Pool Heater - Inground
Hi, I have a hayward H millivolt gas pool heater that started up fine this season but now the standby light is light and I cannot get the panel to do switch..Unfortunately I misplaced the manufacturers...
There is no standby light in the millivolt heater. If you have a standby light it is an electronic fired unit.
If the board is locked in standby, try powering down the circuit feeding the heater and see if it resets itself. If not you'll need a new control board.
Jul 09, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
D.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward 150 Pool Heater- cannot get lit
Your pilot head is probably clogged with spiders. Disassemble and clean it out and it should start working.
Jun 03, 2009 | Hayward 150k Lp H Series Spa & Pool Heater...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
496 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
