Question about Sherwood Audio Players & Recorders
Sherwood AX-4103 amp keeps clicking
Hi, I have an old (20+ yrs) Sherwood AX-4103 amp that has recently started clicking when sound is relayed through the speakers (doesn't seem to do it when it's just on headphones). Any ideas what the cause might be? I've never done any electronics repairs but I'm happy to have a go if someone can help me out with instructions :)
  • Len Phillips
    Len Phillips Apr 23, 2014
    Thanks Ian, I'll give those a go and see what happens :)
    Scholar:
  • 131 Answers
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Posted on Apr 23, 2014
dunnbiker
  • 8546 Answers
SOURCE: RD-6500 Sherwood amp
What model RC? Doesn't its manual give some clues?
Posted on Apr 04, 2009
  • 4234 Answers
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Posted on Apr 12, 2009
SOURCE: does a Sherwood rx-4103 have a circuit breaker?
i have the same problem with mine and i cant seem to figure it out... it clicks off around 4 seconds
Posted on Aug 30, 2009
  • 532 Answers
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Posted on Jul 11, 2010
  • 18 Answers
SOURCE: SHERWOOD KEEPS CLICKING TO STANDBY
proly a fuse thats costs about 6$
Posted on Aug 11, 2010
Why Sherwood Receiver will NOT turn off. It's stuck in VCR mode?
Unless it has some kind of "child lock" mode, in which case you should see the manual about how to reset it. It sounds to me that there is a fault on the microprocessor that controls the functions. It's not something that could be solved other than by an engineer.
Look around for a service centre for Sherwood on the net. Richer Sounds in the UK sold a lot of these, they might be able to help you.
Aug 14, 2014 | Sherwood RX-4103 Receiver
I have a sherwood rc-107 and can't find the code for my grey comcast remote.
Hi John,
You may view the manual and code of your remote control, click this link http://www.comcast.com/corporate/customers/customer_support/remotes.html.
Hope I helped you.
Have a nice day!
Feb 19, 2011 | Sherwood RX-4103 Receiver
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Technics turntable plays but no sound with Sherwood receiver
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Does a Sherwood rx-4103 have a circuit breaker?
Apr 07, 2009 | Sherwood RX-4103 Receiver
Sherwood AX-7030R don't work
Try Googling (Sherwood)(AX-7030R)(manual) without parens.
Dec 20, 2017 | Sherwood Audio Players & Recorders
Sherwood AX-7030R amp - doesn't switch on.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Dec 16, 2008 | Sherwood A-965 Amplifier
Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Apr 05, 2006 | Sherwood RX-4103 Receiver
105 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
