Question about Lincoln Welding Tools
Ranger tires need 2 tires for a Lincoln ranger 8 welder in eastern NC.
  • 708 Answers
Believe it or not call Wallmart, they just might have the tires you need. Or try one of the tire .com places, just enter your tire and rim size, most the time they will be tax free with no shipping charge. automotivewarehouse.com might carry them. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Posted on Apr 30, 2014
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
luis_david
  • 407 Answers
SOURCE: how do you hook a miller s-22p8 wire feeder to a
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Posted on Dec 17, 2010
I have a ranger 305d how can i set it up to weld aluminum?
You may not be able to unless it is DC voltage You need the special rods for welding aluminum but my understanding is it takes a DC welder to use them.
Mar 11, 2013 | Lincoln Electric Ranger 305D K1727-2...
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I have a kohler engine on my ranger 8 welder and i can get it to run for a few seconds then it quits or if i keep putting gas in the carb it will stay running .
sounds like filter/line blockage....check all lines and clear them of any contamination...maybe some dirty fuel or water in fuel has been added into the storage tank.
Jul 23, 2010 | Lincoln Electric Ranger 305D K1727-2...
Auto high idle lincoln ranger 8
Apr 29, 2009 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Lincoln ranger 250 voltage problem
Regards,
Carl
Feb 23, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Welding Tools Logo
63 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
