Question about Annovi Reverberi RMV2.5G27D Pressure Washer Pump
Missing part lost brass plug on bottom
    New Friend:
  • 31 Answers
It's pipe thread, measure hole size and try a good plumbing supply depot. Attach a lanyard to the plug to avoid losing it next time, or re-install it after drawing.
Posted on Apr 23, 2014
No pressure
There may be an issue with the pump. You can take the pump head off to check the seals, or take it to a service center to have it checked.
Feb 12, 2013 | Garden
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
Jan 14, 2013 | Boston Acoustics Audio Players & Recorders
The switch I am replacing has two red plugged into the back and two black plugged into the one below. If I want to keep the same set up I can just connect the two red to the top brass screw and the two...
If you can tell me, The reds are to a light or something right? and are they tied together in a wire nut with a black wire or are there two blacks together and two reds together? If so then you can wire it that way and break the brass crossover but if they are two reds and two seperate blacks then you could have an issue. Let me know further, thanks.
Apr 08, 2011 | Leviton 15A Decora Electrical Outlet Light...
What is the best way to remove and replace a leaking drain plug from the heater? The wing portion has broken off and the threaded brass core doesn't seem to turn even with vice grips. Any suggestions??
If the brass core has flat sides like a bolt or notched in any way then it will come out. It may have been put in with thread sealer so it will be tough. If you could push most of the water out with air, then you can heat up that brass plug and it will easily come out. If you can't get the water out then you will just need to use a large socket set or larger vice grips to clamp on enough to break it loose. If you have room to swing a hammer you should rap on the bottom of the brass plug (core) about 10 hard times. This will oven break the rust or thread lock stuff.
Sep 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have to use the pull start option on my mower because I lost the charger cord. Now it takes me about 20-30 pulls to get it to start. What is the problem?
First...use only clean SAE 30 oil for the Briggs 6.75 engine..2. Make sure the air cleaner isn't clogged with dirt/grass etc. 3. Use fresh gas (less than 1 month old). You may need the carburetor or spark plug cleaned or both. The plug is easy. If you don't want to buy another one, clean with solvent and wire brush. The brass bolt that holds the bottom bowl on the carburetor may need to be removed and cleaned (it's the carbs main jet). Look for very small holes at bottom of bolt and on the smooth sides of it.
Sep 14, 2010 | Toro Lawn Boy Push Walk Power Mower 10640...
No fuel to cylinder
The fuel flows throuth tiny holes in the brass bolt which serves as the metering device or "jet", the fuel flows up through the hollow center of the bolt where it mixes with air and is sucked into the intake manifold, through the intake valve and into the engine. I suspect the brass bolt's tiny hols are plugged or partially plugged.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Where is the old drain plug located?
The oil drain plug is located on the bottom of the engine towards the front and nestled in amongst the cooling fins. The is usually a brass washer, which can be lost easily, so look for it.
Mar 21, 2010 | 1985 Suzuki GS 700 ES
NEED A BRASS PLUG THAT GOES IN THE BOTTOM OF MY CARBURETOR ON A 12 HP SUMEC ENGINE THATS FOR A POWERMATE GENERATOR.
check with your local automotive supply the do carry small engine carb kits.They may or may not have your kit but can order it or tell you where to find it.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Oil plug location for '91 Volvo 940
no, its on the bottom, big 1" brass plug very bottom of engine, easiest to get to from the front, I own the same car....
Nov 08, 2008 | 1991 Volvo 940
Annovi Reverberi RMV2.5G27D Pressure Washer Pump Logo
57 people viewed this question
Top Annovi Reverberi Garden Experts
Bill Boyd
fasteddy
fasteddy
Level 1 Expert
jeff chenault
jeff chenault
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
