Question about Samsung Galaxy S Iii S3 Gt-i9300 16gb Marble White Gsm Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 - Pre-order
How can i reset my phone with the emergency call screen,i locked myself out my phone
Trying to unlock my phone using the emergency call screen,i put in a pin and cant remember it
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Posted on Jul 04, 2014
  • 19 Answers
SOURCE: forgot security lock/unlock code and now i cant use my phone at all.
call the phone comp they will eset i for you
Posted on Jun 02, 2009
Rahilzari
  • 135 Answers
SOURCE: I cant remember my phone lock password - how do i
the code is 1234 or 0000 if non of this work then plz go to the site www.unlock-samsung.eu
Posted on Oct 12, 2009
aliyancheema
  • 1118 Answers
SOURCE: NEED DEFAULT RESET CODE
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
type *#06# on your phone to get it.
Posted on Jul 11, 2010
ishaqazmi
  • 80 Answers
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it. samsung_i9000_galaxy_s_hard_reset.png
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
Posted on Oct 17, 2010
  • 3 Answers
SOURCE: My son changed the password on Samsung Focus phone
If you're still stuck. More then likely the only thing to do is a factory reset, I locked my own self out of the phone within the first 20 minutes I had it. Only after a certain amount of incorrect inputs, it put a time limit, and at the end of the time, every failed attempt doubled the amount of time I had to wait. You will lose everything on your phone if you do you do this.
1. Press and hold the Camera, Volume Down, and Power buttons simultaneously.
2. Release Power when the phone vibrates, but continue to hold down Camera and Volume Down.
3. Release Camera and Volume Down when the Format prompt is displayed on screen.
4. Press Windows logo.
5. Press Windows logo again to confirm the hard reset.
This is exactly what I did, and it worked.
Posted on Feb 24, 2011
My screen is saying. Emergency. Call how do I get this off
There are two possibilities to your phone shown Emergency Calls only.
1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your mobile phone,definitely your mobile phone restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit Unlocking4U.com I hope it will be very useful to you.
Sep 11, 2014 | Cell Phones
How to b ypass emergency lock screen on my x10i
There are two possibilities available to your phone stuck on emergency lock screen
If your problem persists after switch on your phone means definitely your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit MobileUnlockSolutions.com I hope it will be very useful to you.
Feb 22, 2014 | Sony Ericsson Cell Phones
My htc is lockd it can make emergency calls only and i forgot my password
It says Emergency Calls means it locked to Network Lock,You need to Unlock it from Network Lock,You can get the Unlock code at
http://www.mobileunlocksolutions.com/htc-touch-hd/rs1wp9/ and Unlock it,Then You can get the password code from service provider as free of cost,.
Apr 13, 2011 | HTC Cell Phones
Samsung impression a877 lost password to unlock
A hard reset will clear everything out of the phone and reset your password. To perform a hard reset on a samsung take out the battery and removve the sim card and power on the phone. when it comes back on type in *2767*3855#. The phone will go thourgh a reset process and when it comes back on take the battery out again and put your sim card back in and power on. It should be completely cleared including the security password.
Feb 03, 2010 | Samsung SGH-A877 Impression Cell Phone
Nokia 5800 xpress music wont unlock and is flashing
after long search the forum and crafts on the phone all I even managed to repair the problem the phone to lock automatically when startup bug which he and impossible to unlock with unlocking the switch that unlocks the screen and keys, so here is what I do to reset it:
1-your smart phone with another and you must lock your chip with the PIN for your nokia you to save the PIN at startup
2-when the phone asks you to put the PIN code emergency call that is "112" to issue an appeal, you will find the digital bottom right of the screen when you click over the frame screen appears but impossible to put the code * # 7370 # for hard reset not panic please leave the call and put the PIN code 0000 or your own code if you change;
3-when you put the code the phone starts normally but the home screen something changes in the key to the vanishing locking and screen and keys shall be free;
4-so you can do the hard reset and the phone takes its original form
dw: I tested yesterday on my nokia 5530xm and is the only solution,
Dec 28, 2009 | Nokia 5800 XpressMusic Smartphone
Locked out of my LG xenon need subsidy code
1-Remove sim card and tap emergency or From the standby screen
2-Select Dialing Button
3-Dial "3845#*500#" (you will then be in the engineering menu)
4-Reset phone
Your password should now be removed.
Sep 23, 2009 | LG Xenon GR500 Cell Phone
Can you unlock a usim locked phone?
Try taking out the sim card and then put it back in or bring it to the store you bought it at see if they have a bypass code
May 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I can not unlock my T-mobile wing
Just do a factory reset
Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
May 09, 2008 | T-Mobile Wing™ Smartphone
Samsung Galaxy S Iii S3 Gt-i9300 16gb Marble White Gsm Factory Unlocked Gsm I9300 S3 3g Hsdpa 850/900/1900/2100 - Pre-order Logo
156 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
