Question about LG Televison & Video
Wont start causes problems with dish network box, and won't turn on properly.
  • LG Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 21, 2014
My dish 311 receiver goes on and off when connected to dish pro plus lnb
rdjennings10,
It does sound like there could be a power problem with the receiver. The Dish Pro Plus LNB won't cause any issues with that receiver. If the receiver is plugged into a power strip or surge protector, try plugging it directly into the wall. If it is already directly into the wall, try a different outlet if available.
If the problem persists, we will have to replace the equipment. You can reach me at thomas.faust@dish.com to get that taken care of.
Tommy Faust
DISH Social Media Representative
Oct 30, 2012 | DISH Network Televison & Video
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
Jul 31, 2010 | DISH Network 322 DTV Receiver
DISH NETWORK RECEIVER 625 WONT STAY RUNNING???
Unfortunately, there is no way of saving your DVR, i would ask Dish for an upgrade to a Vip series rec, for example a 622 or 722 which can allow the use of an external hard drive. it also sounds like your root problem is with the voltage in the outet your dvr in connected to, try to plug directly into wall, if it is already, have an electrician check your voltage to prevent future issues.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
DN receiver wont stay on.
It's best to troubleshoot with a technician over the phone to actually try things, but it does sound like this receiver is no good. If that's the case and it's leased, you can contact Dish Network and get a replacement at no cost, just pay for the shipping (unless you have Dish Home Protection Plan - then it's free).
Jun 24, 2009 | DISH Network 311 DTV Receiver
Dish Network remote wont control tv2 on my dual tuner
Your problem may be as simple as having the UHF antenna on the back of the receiver moved closer to the second TV. I suggest pigtailling it. This is a job best left to a professional due to the different configurations that may exist and assuring you have properly made connections. If this is an ongoing issue talk with the CSC agent and refuse to pay the service fee based on your past issues with the system. There are many other possibilities that could be the cause but this is the most likely and least involved approach and I am 99.9 percent sure this will solve your issue. Thanks for using Fix Ya.
May 07, 2009 | DISH Network IR Remote Control
Dish net 311 no power
Dish Network (Echo Star Communications) is a problem company. The best solution to your problem is to switch to cable or Direct-TV.
Dish Network should be avoided at all costs.
May 06, 2009 | DISH Network 311 DTV Receiver
A new HD box from dish network has caused a problem with red tint
Call the dish network as they will fix you up for free rather than lose you as a customer.
Apr 07, 2009 | Zenith IQD61W35 61 in. Rear Projection...
Dish network 322
What you have is not too uncommon. It may take a bit to explain, though.
I would bet that you have at least one more Dish box in the house. I know this because that box is the one that is (more or less) causing the problem.
First things first: Go out to where the cables come from the dish and go into the house. You should find a ground wire that goes from the ground block to your power meter box. It should be a fairly heavy gauge, and it should be green. It is attached to a shiny ground block that should have cables attached to either side of it (or splits the cable in two to pass through it). If you do not see anything like this, you might want to look in your attic or crawl space.
If you still have not found it, then whoever installed your system is in direct violation of NEC, and is causing your equipment to mess up. Call the istallers and demand to have this potentially dangerous situation taken care of.
The Alpha box (the one in the house that does not mess up) is causing the 322 to lose its command of the dish LNB (the eye of the dish). This happens because there are stray voltages flying up and down the cable at frequencies that match the ones being utilized by the boxes, and since the system is not grounded (or grounded improperly), these stray voltages have no place to go.
This is the quick and dirty version of whats happening. The LNB might have to be changed due to damage from switching so fast for so long.
Hope this helps you...
Jan 10, 2009 | DISH Network 322 DTV Receiver
Controlling my Sylvania LC320SS8 with my Dish Network remote
Try these Sylvania codes: 10054, 10030, 10171, 0030, 0054, 0171, 1944, 1963.
These weren't listed in Dish Receiver manual.
Apr 09, 2008 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
151 people viewed this question
Computer Repairing
Computer Repairing
