Question about Home
Dukane clock system needs security code reset.
We have an old Dukane clock system, model # 24A701. During the recent power surge I believe it was knocked out. Does anyone know how to reset the security code? It will no longer take the one we've been using and half of the users manual is missing.
  • Andrea
    Andrea Apr 23, 2014
    I figured it out. Thanks to all that looked! The security code reset to 0000, if anyone else may have the same ancient system with the same problem!
jqsababa967
  • 145 Answers
SOURCE: Minolta Di 351 code C0500 & need reset code for this
look for a small hole...on right side of the disply panel...THE HOLE IS SMALL THE SIZE OF PAPER CLIP IN DIMETER..IN FACT THE ONLY WAY TO ACCESS IS BY PAPER CLIP.PRESS IT ONCE VERY GENTLY..AND WAIT FOR A SMALL DOT TO APEAR ON THE LEFT SIDE OF THE SCREEN IN THE CENTER.ONCE YOU SEE IT>>PRESS # 3 than you will be promted by a screen to reset troublr code press it to conform MACHINE WILL RECYCLE
HOPE THAT HELP S
GOOD LUCK
Posted on Dec 31, 2008
SOURCE: Clock Setting Mercedes benz ML320
pull on the noob right next to the time one way changes hours other way changes min. !!!!!!!!!!!!!!pull hard on noob that you can turn it!!!!!!!!!!!!!!!!!
Posted on Jan 11, 2009
  • 7 Answers
SOURCE: Thermostat + User Manual
Stoves are still there you can contact them on 08712222502
Posted on Jun 01, 2009
  • 26 Answers
SOURCE: Does not power up.
chuck05,
You might try to find a reset button on the back of the unit. Also, the Aiwa website may have a "support" staff that can see if they have an archived manual or tell you which buttons to push. Also, check to see if the unit has a fuse in back. Finally, check a website called audio.manualsonline.com . It's a free deal where people exchange manuals and information.
chrisxx
Posted on Jun 03, 2009
  • 105 Answers
SOURCE: Security System on 2005 Dodge Ram 1500 malfunctioning
if you do not want to go back to the dealer then take it to an alarm shop which does private installations on cars and trucks because most of the time when they install after market alarms they bypass them or just pull out the factory alarm altogether.
Posted on Jul 26, 2009
My system is password locked and I cannot remember the bios password
You cannot bypass the password security yourself. If you could there would be no point in having password security on all our devices.
Jan 13, 2016 | Computers & Internet
Wall Clock Won't Keep Time
Disconnect it. Plug it back in. Go to the office and tell the master clock to reset all the clocks. It sounds like it is searching for guidance from the master unit.
these people may be able to help specifically if you don't have instructions for the master unit.
http://stevenengineering.com/tech_support/PDFs/57MAIN_CLOCKS-TIME-SYSTEMS.pdf
This is the way I did it when we have all the clocks in a hundred room hotel to change when the clocks change in the UK. I went back to the same hotel 35 years later and asked if I could see when the cupboard where the clock was reset, and the unit was still there, albeit not working. It was replaced for a more modern system, of putting clock radios in rooms.
Aug 19, 2017 | Dukane Audio Players & Recorders
Hello i recently had to disconnect my sony MEX-5DI stero and now it wants a security code which i dont have, i have no manual either. is there anyway i can find out the code?thanks
Hope this helps, if so please feel free to rate? (I have added a link for your manual also)?
Before operating the unit for the first time, or after replacing the car battery or changing the connections, you must reset the unit. Press the reset button with a pointed object, such as a ball-point pen. After the reset is complete, the pre-stored images are displayed. Press (image) on the card remote commander to show the clock display and set the clock and calendar. * Pressing the reset button will erase the clock calendar setting and some stored contents. * The unit starts to perform initial setling for IO seconds after you press the reset buttof). During this, do not insert a disc or "Memory Stick," othetwise the unit may not be reset. Should this occur, press the reset button again. * The unit makes some noise during the initial settings, this is not a malfunction.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/158/158MEX5DI.PDF
Mar 28, 2011 | Sony MEX-5DI CD Player
We have an old Dukane clock system (Serial # B1249718) Model # 17A365 - and we have no instructions on how to reset the clock when daylight savings time begins or ends. We are in a school and the manual...
On the front keyboard push:
1 <then> # display is now looking for password push:
9999 <then> # display is now looking for program choices
Look on the face of the master clock for a list of choices....enter these choice #s and you will be able to follow the rest of the programming.
When done press *
Nov 30, 2010 | Office Equipment & Supplies
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
In line fuse
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Mar 27, 2008 | Bose Wave Radio
Home Logo
75 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
