Question about Behringer Audio Players & Recorders
Where can i find the schematics for bugera 333xl
  • 483 Answers
here is the schematics download-able:
BUGERA 333XL SCH Service Manual free download schematics eeprom repair...
Thanks,
gylacz
Posted on Apr 22, 2014
3 Suggested Answers
  • 5 Answers
SOURCE: Bugera 333XL Amplifier does not power up. Valves do not light.
Steve,
That's a nice amp head.... If it is still blowing fuses, you've got a dead short somewhere, that probably is in the power supply section. The power supply is solid state, (diodes for the rectifier), so either one or two didoes went bad or one of the big filter caps shorted out. Look for a blackened area around these components. Sometimes the caps will have just a "puffed-up" look to them, but.. BE VERY CAREFUL! Some tube amplifiers do not have bleeder resistors on the caps and they can hold a charge of up to 450 volts... Very dangerous! AND can KILL.
If you don't know what those components are, or how to use a volt/ohm meter, you should take it to a technician.
Posted on Aug 22, 2009
caroldon
  • 17129 Answers
SOURCE: bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
Posted on Jul 24, 2010
Where can I get a schematic diagram of the Bugera 6262 Infinium Guitar Combo Amplifier?
Bugera - MUSIC Group
https://www.music-group.com/brand/bugera/home
Notice of Scheduled Maintenance. This is to advise you that our system will be unavailable on Saturday, January 9, 4PM - 6PM, SGT. Please plan accordingly.
Page 44: Bugera Users' Militia (for all things Bugera) @ Ultimate ...
www.ultimate-guitar.com/forum/.../index.php?t...
Ultimate Guitar Archive
Aug 17, 2011 - 100+ posts - ‎68 authors
I really like the cleans on this amp, and I don't consider using the overdrive.. so better tubes will ..... Its a 6262 212 combo ... 6262-212 INFINIUM 10/06/2011 ..... is there aschematic for this mod somewhere floating around? Page 48: Bugera Users' Militia (for all things Bugera ...
100+ posts
Jul 15, 2013
Bugera TriRec - First pricing (US) @ Ultimate ...
100+ posts
Apr 19, 2010
More results from www.ultimate-guitar.com
Rig-Talk • View topic - Bugera Amplifiers
www.rig-talk.com/forum/viewtopic.php?t=138566&p=1605914
Jun 14, 2013 - 50 posts - ‎12 authors
Jan 11, 2016 | Bugera 6262-212 Infinium Guitar Combo...
Bugera trirec infinium schematics
Make and model would help somebody find them.
Jul 13, 2014 | Audio Players & Recorders
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
I need the schematic for my vt series model-212 deuce, serial number 9 A-379 90
Here you go... the parts list is at the front.
http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Scroll down to "Get Manual" at the site and click on it to download the manual.
May 05, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
I would like a wiring diagram for Bugera 333XL footswitch.IE the plug connections.
intel d865gvhz i have install but beep sound continuly is there but what problem this is
Apr 02, 2011 | Computers & Internet
Hi , i have a Bugera 1960 and my problem is send-return...when i put my boss ge-7 equalizer in it i can t hear the fx and this is the same thing for my delay pedal...i can hear but realy realy little...
The problem is the BOSS is designed to handle a guitar level at -20Db and the effects level is designed to run at either -10 Db or +4 Db. You will get better match setting the Bugerra effects to the -10 setting on the back and reducing the level... HOWEVER the pedal will want to send -20Db out which is 10 Db under what the effects return wants to see. This is a factor of three roughly in gain so the signal will be low. This is the problem using a guitar pedal in a way it wasn't designed to be used. The effects loops are looking for "line level" NOT guitar levels.
Schematics aren't going to help. The normal thing is to connect your guitar to the pedal and send the output of the pedal to the amp.
Guess what? The same things apply to your delay pedal... they are intended to accept the signal from the guitar OR the guitar like level from another pedal such as the GE7.
Mar 17, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Bugera 333xl every few seconds there is a loud buzzing. from
May 16, 2010 | Audio Players & Recorders
Need Schematices
Try posting on some of the guitar forums. The schematics you are looking for are only available to licensed repair persons but you might get lucky and find someone who will send them to you. Be sure to state what model amplifier you want. If you are a tech try looking at some schematics for a similar amp and tracing the circuit.
Jan 21, 2010 | Music
Steve,
Aug 03, 2009 | Behringer Audio Players & Recorders
277 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
