simply change the fuse by its own,,if it wont turn on by replacing the fuse try to test the switch power ,,that would be the last problem so your tv wont turn on
.First check fuses in fuse box inside vehicle,if good then,Go to head light with meter,remove connector,turn lights on and see if you have power,do both,if no power then maybe switch.Here's the switch.
Yes, check the incoming fuses over by the main power transformer first. If the fuses are good, the next check will be power switch and then transformer itself.
have you checked the fuses inside the set. The power outage could have surged just enough to blow the fuse. Dont forget to unplug it when you check the fuse.
