Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
FORGOT MY WEP CODE - Actiontec GT704WG Wireless Router (gs583ad3-01)
    Scholar:
  • 94 Answers
I WILL NEED TO KNOW YOUR ROUTER'S MODEL/MAKE!
First, go to your router's ip address (depends on each router)Then, login to your router (default username: admin default pass: blank or admin)
There, under tools or network security or similar to that sort, look for your network/WEP key. There, you should be able to find your network key to access the router's network, and even change it if needed.'
Hope this helps, please rate ^_^
BE SURE TO TELL ME WHAT ROUTER YOU HAVE THROUGH COMMMENT! THANK YOU ^_^
Posted on Jun 19, 2009
    Problem Solver:
  • 18 Answers
Use this software to hack your own router, i have done this a number of times.
http://wepcrack.sourceforge.net/
If that doesn't work, you can do it the manual way, as noted here:
http://www.wirelessdefence.org/Contents/stepbystepWEP.htm
Hope this helps!
Forgot the wep key code.
If you forgot the wep key to your internet your best solution would be to reset your router and restore all of your settings to their default value. There should be a rest hole on the back of the router. simply hold down the reset button and then log back into the router using the default ip address (try either 192.168.1.1 or 192.168.0.1) and the default username and password. Once you do that you will have to go and set all of your values again such as your network name and your new wep password.
Hope this helps!!
Apr 27, 2011 | D-Link Wireless N 150 Home Router 4Port...
Hey, I Have a Ninteno DS Lite, im trying to find an access point through my Belkin N Wireless Router F5D8236-4 v2 It shows up but it asks for a WEP key. if this is the passcode to my internet, i'm trying...
WEP key is the security code used in your router. If you forgot your wep key you can check it in your router's security settings. You can access the setup page of your router by :
1. Open your browser (ex. Mozilla, Google Chrome)
2. Type in the address bar 192.168.2.1
3. Enter your password (by default the password is just blank so you can just hit submit without typing anything)
4. Then click on the wireless tab, from there you can check your wep key in the security tab. You can also edit any information you want it that page.
Mar 10, 2011 | Video Game Consoles & Games
I forgot my wep code and i need a way to get it back.
type 192.168.0.1 on the address bar of IE (no http or www )( on a hard wired computer and when you are online ) and you will in a GUI - select security under wireless and find the wep key there
(in case you are receiving the message enter user name and password - try admin on username and hit enter)
Oct 04, 2010 | NetGear DG834G Router
Forgot my wep key. How do I get it?
You can sometimes retrieve it from the router settings, but barring that, there really is no easy way to get it.
Note that I said easy. If your router is indeed using WEP, you can sniff the packets coming off it with sniffers and once you have enough packets, then you *might* be able to decode the WEP key code. This usually doesn't work out very well though.
Jun 13, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I have a new laptop but forgot my password for my linksys WAG200G wireless router so have done a hard reset but now I can't get any laptops to connect.I have a 26 digit code but not sure if need anything...
as i know, if you have done the hard reset linksys will reset to default setting in this case your 26 digit WEP code no longer effect. you should login to admin to set your setting. may be you can read the manual again or see support/WAG200G
May 13, 2010 | Linksys WAG200G Router
I forgot the password of my dwl-900ap+ and can not connect additional pc to the wlan. Help
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 10, 2010 | D-Link Air DWL 900AP (DWL-900AP) 802.11b...
Need wep key code
The wep key is set by the system admin when the router is installed, contact the systen admin to get the wep key.
If you forgot it you have to reset it but logging into the router's setup through a browser by typing its IP address, then going to Wireless Network Security and changing the WEP key.
Hope this helps,
Cheers,
Jan 06, 2010 | D-Link AirPlus DI-524 Wireless Router
How do i connect my wifi if i forgot my password
your password should usually be somewhere on your router box if you have a mac it is probably the code next to mac if pc than its the code next to wep
Oct 28, 2009 | Apple iPod touch
Forgot my router's wep code
D-link routers usually have a sticker on the bottom with this code on
Aug 01, 2009 | D-Link AirPlus® G DI-524 Wireless Router
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
343 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
