Question about Whirlpool Washing Machines
Whirlpool Cabrio 580 is unbalanced and will not complete a wash sequence
I put in a load, add the soap and turn it on and it always gets hung up at 11 minutes left. It does not matter if I select Normal, Colors, Heavy Duty, Bulky Items, or Whites; they all stop about with about 11 minutes left and keep adding water to the load and then it will spin and get unbalanced and stop. If I reach in and move the clothes about and reposition the items, then it will stop spinning and get hung up. If I do get it to move forward, which never seems to happen then it will stop and keep adding more water and the process starts all over again. HELP!!!!!
    Problem Solver:
  • 20 Answers
USEUALY IT IS MOST LIKELY THAT THE UNIVERSAL JOINT UNDER THE WASH PLAT AT THE BOTTOM OF THE TUB HAS GONE OUT .SHOULD BE REPLACED . THAT SAID PROBLEY WISE TO GET A TECH TO REPLACE IT . ON THESE YOU HAVE TO HAVE A SERVICEMAN TO REMOVE AND REPLACE THEM ..
Posted on Apr 26, 2017
likha
  • 790 Answers
SOURCE: Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Posted on Nov 02, 2007
SOURCE: My washer keeps on stopping in the middle of the spin cycle
Take the lower front cover off, 3 screws on bottom.
Put bucket under right side, large round piece.
Unscrew large white round piece, dump change and lint out and put back together. I did it today.
Posted on Jan 20, 2008
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Posted on Jan 06, 2009
SOURCE: Samsung front loading washing machine won't spin out.
I have the exact same symptom with mine that is only 4 months old. I have a technician coming as soon as the part is available. The problem is the PCB control board. Samsung has corrected a known issue with the original and has manufactured a new one. This is a known issue and thus the part is hard to get. I have, however found a temporary fix. Unplug the machine for about a half an hour. I haven't figured out how long to do it exactly but when you plug it back in it should read PF for power failure. It's the equivalent of a reboot for your pc. I got about 3 days of service from the machine before it stopped spinning again. Another reboot and I'm back in business.
Posted on Feb 08, 2009
We had the same problem. We ordered the washer on Black Friday and just got it this past Sunday. We put laundry in and it would not spin. We got the dc code. We have been on the phone with Sears for the week. A repairman came out to look at the washer today. He couldn't find anything wrong and had to call the tech people for help. They said if the washer is in a space that is below 60 degrees it won't spin because the oil in the back of the drum is too thick when it is cold. They have to order a new board to heat the oil. We thought they were crazy. So we did our own experiment and put a heater in the basement. The washer worked! Now we are just waiting for the new board to see if that solves the problem so we don't have to heat the basement just to wash clothes. I am glad we can at least heat the basement and wash clothes until the part comes. I will post after it has a new board!
Posted on Feb 21, 2009
Whirlpool cabrio top load washer ul on final spin
It senses that the lid is unlocked, even if it isn't. Could be a defective interlock.
Feb 24, 2018 | Whirlpool Washing Machines
Suggest me the best organic soap?
When it comes to selecting soaps for use, I always prefer going organic, because whenever I use Natural Skin Care soaps I feel more secure and better. These are much better than the normal soaps as well. They create no harmful effects on my skin. Non-organic soaps on the market are loaded with synthetic and artificial ingredients, which then cause skin allergies and irritations, not mentioning the dryness and itchiness they cause due to heavy loads of chemicals. With organic soaps, I am able to avoid all these because they pose no harm to my health but only give skin benefits, including moisturizing and nourishing.
Dec 08, 2017 | Best Computers & Internet
My washer always gets unbalanced load with 7 minutes remaining.
This sounds like a problem with an unbalanced washer or unbalanced load. Your washer has four leveling rubber screws underneath. To keep it from rocking make sure all four points are touching the floor at all times. Washer machine being level is a great plus. Also it could be the amount of clothes put into the washer. The more clothes you put in the less chance of your load being uneven.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
My whirlpool cabrio keeps giving Unbalanced Load message and has become very loud lately
Check your pump . make shore water is pumping out of drain hose fast/ if not clean objects in pump or pump impeller is broken? replace pump.
Feb 03, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
47 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
