Question about Ford Vehicle Parts & Accessories
2010 ford 250 blows cold air on drivers side and hot air on passendger side
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ford Master
  • 1,917 Answers
The vacum diaphm behind control heating panel take in cost 100.00
Posted on Sep 04, 2014
4 Suggested Answers
  • 71 Answers
SOURCE: my ac blows cold air on one side and hot air on another
It could be two things. I immediatly think that you have a low A/C refrigerant level. This essentially causes air bubbles in the lines that in turn will cause warm air.
My other though is only relevant if you have dual climate control zones. This could be due to a sticking blend door on the hot side.
Posted on Jul 12, 2013
sxygaman
  • 95 Answers
SOURCE: 2008 azera with dual a/c blowing hot air only on drivers side
trap door in dash closed not letting cold air pass across
Posted on Aug 12, 2012
  • 1003 Answers
SOURCE: The heater on my 1995
replace the blower motor.
Posted on Feb 04, 2013
My 2010 F150 Lariat. The heater blows warm air on driver side but blows cold air on passenger side. What could be the problem?
Does it have dual zone climate? If so, you have to adjust the passenger side. If it still doesn't work, check for vacuum hose off in engine compartment, going into the firewall.
Dec 03, 2016 | 2010 Ford F-150
When air conditioner is turned on the drivers side blows cold air and passengers side blows hot air, rear dual air blows cold air in to back passengers area.
If your sure you're looking at the right motor, Then the door is broke. Dash and plenum have to come out to fix it. Not a cheap fix.
Jul 02, 2016 | 2010 Ford Flex Limited
Air conditioning system, when you turn on the air conditioner the drivers side blows cold air and the passengers side blows hot air? What causes this problem?
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
2010 dodge journey blows cold air on passenger side
Help with heating issues, blend actuator - Interior - Dodge ...
www.dodgejourneyforum.com/.../5304-help-with-heating-issues-blend-a...
Jan 13, 2014 - My 2009 Journey R/T is only blowing hot air out the driver side vents, while the other vents (passenger and rear) are blowing cold air ... Thanks Frogbox....keep in mind that the info is for the 2009 model and I guess it also applies to2010's. 2009 journy sxt heat/cool issue
Oct 16, 2014
Air Conditioning?
Dec 22, 2012
Rear heater A/C
Dec 22, 2012
More results from www.dodgejourneyforum.com
In a 2010 dodge journey why heat comes out just one side
Jan 10, 2016 | 2010 Dodge Journey SXT
2010 Traverse. Passenger-side heater only blowing cold air; driver-side blows hot air and so does rear vents.
This sounds like the actuator door or motor on the heater is not moving. Be sure to check all fuses and make sure you have power to the actuator door.
Sep 08, 2015 | 2010 Chevrolet Chevrolet Traverse LTZ
2010 GMC Acadia driver side vents blow cold air passengers side blows hot air both set at same temperature
There is a blend door on the plenum. It is stuck or not working for some reason.
Apr 17, 2015 | 2010 GMC Acadia
No heat from vents
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
