Question about Apple G3 Computers & Internet
My Mac G3 does not boot anymore!
I get black screen with letters saying: default catch! code fff00400 at.. continues
    New Friend:
Try shut down unplug from wall leave for couple minutes. restart
Posted on May 08, 2014
    Problem Solver:
  • 4 Answers
Try a safe boot.
OS What is Safe Boot Safe Mode
If that doesn't work, try reseating your memory chips. Or take them out apart from one or replace them. The error sounds like a RAM issue.
Posted on May 07, 2014
3 Suggested Answers
wolfy007
  • 14 Answers
SOURCE: Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Posted on Apr 14, 2014
willell
  • 67 Answers
SOURCE: Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Posted on Jan 18, 2010
Ibook g3 won't boot
If it turns on and you get a gray or blue screen with an Apple symbol and a rotating circle - your hard drive it shot and you need to get a new one.
Dec 31, 2010 | Apple iBook G3 Mac Notebook
My ibook (G3 700 two USB) stars but the screen continues to be dark I willl like restart, without any problema about data
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Nov 20, 2010 | Apple iBook G3 Mac Notebook
When I turn on my mac g3 works but the screen stays
Some models of G3 iMac have an external display connector under the rear belly plate. Connect a monitor to this connector. If that monitor shows your desktop, your main CRT is blown. The cost of replacing a CRT in this model is almost certainly more than the residual value of the machine.
May 29, 2010 | Apple iMac G3 Desktop
During bootup, makes pong sound then goes to white screen, no cursor. Apple g3 14" running 10.4
Its a hardware failure! Usually a hard drive failure.
If you have the software Mac Tools, put that cd into your drive and boot the mac tools software to test the hard drive.
If the hard drive passes, then the software is corrupted and need reinstalltion.
Please write me back to tell me if this helps
Mar 19, 2010 | Apple iBook G3 14" 800MHz Mac Notebook
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
Prblem after upgrading a G3 to Tiger
I see you posted this problem twice, and the other one has more details, so if you don't mind I'm going to close this one and answer the other one.
Oct 05, 2009 | Apple iBook G3 Mac Notebook
G3 series 1998 notebook
This has always been a tedious problem to solve. The best advice I can give you is to use the law of halves, create an "Extensions Disabled" folder next to the "Extensions" folder. Move half of the extensions into this folder and restart. If that helped put half of them back, if it didn't help, remove half the remaining active ones. By repeating this process you can rather quickly ascertain which is the problem extension with just a few restarts. Say you have 120, then 60, then 30, then 15, then 8, then 4, then 2, then solved. From this example you could deduce the exact culprit from 120 possibles with just eight restarts.
Jan 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
When i turn on my mac ibook g4 the screen gets light then suddenly goes dark and seems to boot up but the screen is black but i can faintly see the desktop icons. What should it do?? thanks
your backligny is probably off. try "increaseing the brightness" on your screen. on macs that should probably be one of the F-keys at the top of your keyboard. I think brighter is F2 or Fn + F2 or somethinglike that. just find the symbol. Do this while your laptop is plugged in to make sure it's not just dimming you screen to save battery.
Dec 29, 2008 | Apple iBook G3 Mac Notebook
My iBook is Sad.
I would connect another monitor to it, if you see the same on the monitor, the videocard/GPU is toast, if not , the onboard display is.
Aug 22, 2008 | Apple iBook G3 Mac Notebook
Computers & Internet Logo
41 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
