Question about TurboChef TORNADO Electric Oven
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
The EC cooling fan is ALWAYS running at full speed. Turbochef says it should run when EC gets over 120 degrees, but I don't think it is that hot. Not comfortable opening side panel with oven running and 4000 volts there.
  • Larry
    Larry Apr 22, 2014
    Thanks Jim and Lou. The unit is clean so I know I have good air flow, and I replaced the EC cooling fan in hopes it would be quieter. It just runs full speed 100% of the time. Where EXACTLY is the temp monitored? Is the fan either on or off, without having slower speeds? It is definitely pulling a lot of air through the EC and I don't think its over 120. Wondering if temp sensor is bad and/or easily replaceable? Service call will cost hundreds. Thanks.
    Problem Solver:
  • 6 Answers
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Posted on Apr 21, 2014
  • 125 Answers
SOURCE: turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 75 Answers
SOURCE: Problems with TurboChef TORNADO Electric Oven f8
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Posted on Jan 28, 2010
  • 75 Answers
SOURCE: I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
  • 17 Answers
SOURCE: My turbochef tornado gives an error messag of
Could be the speed control PCB, or the motor, You need to test the impedence of the motor. You may have to replace both the motor and the PCB.
Posted on Mar 01, 2010
  • 15 Answers
SOURCE: TURBOCHEF C3 AND TORNADO
to change temperature press up and down arrow keys simultaneously when asked for pin press 9 then the enter key you can now change temperature in 25 degree f increments by using up and down arrows temperature range is 350f to 525f once you have set the temp you want press enter button to set the temperature as the default. To change menu settings is a little more complicated but not to difficult
Posted on Apr 29, 2010
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
What means code F6
I believe f6 ec temp is your code. That means the electrical compartment is getting to hot. Most common is the fan on the back of the oven is weak and not moving the air fast enough. Also the electrical compartment could be loaded with dust.
Dec 11, 2013 | TurboChef TORNADO Electric Oven
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Tornado ngc oven has an F6 code. IR heats up to 1160 degrees but never says ready
unplug oven. Discharge Caps- if you don't know how to do this stop here and call a professional.
push the small red reset switch rear lower corner of oven. IR is a little higher than i like to see.
Test electrical compartment thermal-couple. located under top cover about 2 inches from the rear in center.
Test Electrical compartment cooling fan.
EC Thermocouple (P/N 700-1199)
Type K Thermocouple. Thermocouple measures the
temperature of the electrical compartment. If the
temperature within the electrical compartment is
above 158?F (70?C), the control displays F6: EC
TEMP. The control board checks the EC temperature
every 60 seconds.
Oct 26, 2010 | TurboChef TORNADO Electric Oven
My oven is showing F6 EC TEMP on the screen how do I fix it? Please let me know.
F6: EC (Electrical Compartment) Temperature High
Fault is displayed when the EC thermocouple
exceeds 158?F (70?C). It is monitored once per
minute.
The electrical compartment is overheating. Remove the panel on the right side and clean out all the dust. Check the fan at the back and see if its blowing alot of air. Sometimes this fan can get so clogged up with dirt, it slows down the air flow.
Sep 04, 2010 | TurboChef TORNADO Electric Oven
this is simple to fix but usually costly sorry to say.
F1 blower means the motor is not running when commanded.
first check the motor and verify if it spins freely - if the motor does not spin freeely remove the obstruction or replace the blower part# NGC-1025
just to clarify its the big blower behind the cook chamber not the little fan in the electrical compartment.
Dec 30, 2009 | TurboChef TORNADO Electric Oven
Turbo Chef hi speed oven prblem with 2004 model very loud fan
is this a c3 or a tornado oven.there are afew causes for that type of noise but are diffrent for each type,regards les
May 08, 2009 | TurboChef C3 Single Oven
Turbo chef oven F6 ec code
Feb 04, 2009 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
125 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
