Question about Vinpower Digital U-Print CDP78 Printer
My computer won't recognize my u print printer. I WAS working but now can't be found! I have dleted and reloaded the right win 7 drivers but to no avail. What else can I do??
It WAS working but now can't be found! I have deleted and reloaded the right win 7 drivers but to no avail. I even rechecked and updated my usb bus drivers. What else can I do??
  • northtxcwby Apr 21, 2014
    The driver install portion states it is not compatible with my operating system which is win 7. It is set to be compatible but all of a sudden after I did several win 7 updates this stopped working. The last time Vinpower updated the software was in 2010.was in 2010
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
In WP my print button is not highlighted so I can print a document. Can anyone help?
This sounds like a driver problem.
I suggest you disconnect your printer from the system, delete it from the Control Panel, restart the computer, turn on the printer, then connect it (USB?) to the computer.
Win should recognize that 'new' device and locate the right driver for it.
If it fails to do this, you should try downloading a new driver from the Net for Win 7 and whatever printer brand/model you have.
If the driver is not able to self-install, you will have to go back to the Control Panel and take the 'Add new device' path.
Good luck-
Oct 14, 2014 | Microsoft Computers & Internet
Phaser 8500 - cannot print color under 64-bit Win 7
to start from the beginning, i understand that you are running win7/64bit, usb connected. on base of this assumption we will try to solve your problem. by the way, i love this printer!
1. disconnect printer from usb port,
2. remove all instances of your printer and printer driver from your computer, run ccleaner to clean the junk including registry
3. download again your printer driver (it should be about 6.3mb, lite version which you most probably downloaded will not work!), just in case if previous download was corrupted, choose global english as a lingo.
4. http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=8500_8550&ripId=&Xtype=download
5. unzip file to root directory or desktop, anywhere where you can find them easy.
6. connect your printer to the computer
7. right mouse click on "my computer"
8. left mouse click on "control panel home"
9. under "hardware and sound" left click on "view devices and printers", your printer should be there
10. 2x left click on the printer
11. 2x left click on "customize your printer"
12. left click on "advanced" tab
13 select "new driver"
14. select "have disk" and point search where you did unfold the drivers.
as this particular printer is part of build in microsoft printers, often microsoft is overriding your preferences and this process will allow you to use manufacturers settings not a microsoft.
after this your printer should be visible in printer folder as default. make test print,
if you find this solution useful, please do not hesitate to leave feedback and vote4 for me, if you do require additional help, please call back.
Aug 02, 2010 | Xerox Phaser 8500/8550 All-In-One Thermal...
My canon pixma iP3300 has todaystopped working after printing very successfully for many weeks with windows 7which has now dceided it does not recognise the printer. what can the problem be?
its bcoz u have a win 7 and ur driver version is preety old for win 7 to recognize..
kindly visit canon website and download the latest driver required...
Mar 16, 2010 | OEM Systems PIXMA iP3300 Photo Printer
Windows 7 does not have drivers for Xerox Docuprint P8ex
Hi all, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
Feb 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Won"t install on new computer windows 7
Here is a link to the lexmark site, you can click download Now to begin the download of the file you need.
click here for link to site
Nov 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
The printer keeps going offline. Only resolution is to un-plug the printer. How to prevent this?
Check your settings in the driver. Right click property's and check its not setup to default to work of line. If that all correct then easiest fix is to dlete driver then reload.
Oct 10, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Vinpower Digital U-Print CDP78 Printer Logo
44 people viewed this question
Top Vinpower Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vinpower Office Equipment and Supply Expert? Answer questions, earn points and help others
