Question about Lanier Office Equipment & Supplies
Lanier 5645 feeder
Was working fine. Now won't feed more than one sheet at a time and sometimes not even that. Paper never gets past the second roller. Could it be the little belt (S2M114) needs to be replaced or something oiled?
Tonerman
  • 62 Answers
SOURCE: Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Posted on Apr 29, 2007
  • 186 Answers
SOURCE: Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Posted on Jul 10, 2007
Cogz
  • 1326 Answers
SOURCE: misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Posted on Dec 13, 2008
frankzjm
  • 191 Answers
SOURCE: feed switch unresponsive
your case seems the cassette feed unit can not detected by cassette unit sensor which locate around the paper input roller area.you need to check
1) the cassette push in the well position which can touch the sensor well egnough
2) find out this sensor and adjust the sensor sdander position (more sensitive).
Posted on Feb 07, 2009
SOURCE: Paper won't load. Media loaded incorrectly.
Okay.. 1st off I'm probably going to the jumped on for this... But.. I fix and/or make them work printers, computers and all sorts of electronic gear. For a living... Yes .. the manufacturer will tell you not to use alcohol to clean the rollers. but it does work. Windex (ammonia) will clean the heads at times. I also use Scotch brite pads to clean the pickup rollers. We get them in about 8x10 inch pads.
I will spay some alcohol on the end where the pick up roller is. Place the pad in normal paper tray. Most printers have a cam shaped one on the right, left or in the middle. That gets the paper moving. The pad is way to thick to actually move and will cause a jam indication on the printer. But what happens is the roller will slip on the pad and clean itself. Pretend you cleared the jam a couple of times and the printer will try to pick up the 'paper' and jam again. A couple of these and the pick up roller (cam shaped) will usually be good to go. The other option (the best) is to buy a new pickup roller for the printer. But cleaning will work for the short term. What happens on most printers is the roller gets very smooth from normal use and then won't pick up the paper for the rest of the trip through the printer. I have used a piece of fine grade sand paper, but you have to hold it so it won't go through the printer and it makes a gritty mess... Once I orderd a 'printer cleaner' from HP and all it was, was a couple of pieces of scotch brite glued to a fancy holder to match the spacing of the rollers. That's when I started using sheets of the stuff. Just pretend they are a piece of printer paper. In the worst case I have used belt dressing and then alcohol to clean most of it off. Alcohol has a tendency to soften the rubber on the pickup roller. That's why the company says don't use it. But you can by rubber rejuvenator that is mainly alcohol.. Go figure.........
Posted on Mar 21, 2009
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Always have code 5700
5700 is a sheet feeder error, the feeder in the back where you put fresh paper. What I find most often is something has fallen in the paper slot stopping the paper from feeding. Sometimes ink pens, money, paper clips, nails, candy, and even jewelry. You can turn the printer over and shake it, or look inside with a flashlight and small mirror. Last time was a sheet rock screw. If you find nothing, it's probably a shop repair to look inside.
Feb 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Misfeed on lanier 7320
Dec 11, 2008 | Office Equipment & Supplies
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Canon MP730 not feeding properly.
The machine had never given trouble before, only this time when a new person was using it. So, figuring they may have refilled the paper tray incorrectly, I took out the paper guides at the back and kept hand feeding one sheet at a time. After each jam up I had to reset everything but after about 7-8 tries "something" cleared and now it works fine.
Regards BB
May 22, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Hi there i need some help, I need to find out why my paper will not go into the feeder area of the printer. I have tried different ways and it just won't feed even though the rollers roll. Thanks call if...
This printer comes with major paper feeding problems, even on the FAQ for this printer on HP's website paper feed problem is the number 1 FAQ. It either misfeeds or won't feed paper. An average example is if you try to print a 6 page report, it will missfeed about 10 sheets to print 6, and you will spend a lot of time pushing the paper feed button.
Following the guidlines in HP's faq about this does nothing to improve the situation. HP basically denies any problem with the printer and wants the consumer to pay to ship and have the printer fixed, even if it is new. They will give you phone calls and emails with a lot of PR babble, but do nothing. Stay away from this piece of junk, HP is aware there are major paper feed problems, does nothing about them, and doesn't take it off the market.
Oct 28, 2007 | G7 Productivity Systems VersaJette M300...
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
13 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
