Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Grohe sprayer faucet will not retract, spring around hose below.
Similar sink in house looks the same and retracts fine.
  • 117 Answers
Check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Posted on Aug 01, 2009
    New Friend:
    Problem Solver:
  • 10 Answers
Often there is a weight on the hose to retract it. or it could be hung up on the suppy piping under the sink.
andrew
Posted on Nov 27, 2013
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
Jun 03, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Pull out spray will not retract
check under sink to make sure nothing is stopping it from retracting. It can happen.
Feb 17, 2014 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Kitchen faucet hose will not retract on its own
Faucet hoses use gravity to pull them back down into position. You want to add some weight to the hose or clear the space underneath your sink. Usually a big heavy nut will do the job as well.
Feb 17, 2013 | Delta 24T2621-LS-R6 Single Control Mixing...
My Grohe kitchen pull out faucet will not retract
Normally, there is a weight on the hose (under your sink) that retracts the faucet line. Look under your sink and make sure that the weight is still attached and that there is nothing interfering with the hose moving.
Jun 03, 2011 | Grohe Plumbing
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Good morning my plummer put in my new 980t sd -dst touch 20 faucet....it works so far....however my pull down hose i have to some what push it back up for it to go in......on the video it looks like it...
If you can, look up under sink for hose attached to faucet. There should be a weight on the hose, to assist in retracting it. Usually just a bolted on round lead weight that wraps around the metal sleeve of the hose. Perhaps he forgot it, or it needs to be moved/adjusted by loosening off the bolts that hold it together and sliding it up or down the hose. He may have even routed hose wrong. Have someone pull it out and slide back in while you watch it.
Jan 22, 2010 | Delta 989-SSSD Allora Kitchen Pull Down...
Need to know locations of springs on a Mastercraft D6ME 2 barrel Carburator. This carburator is on my 1977 Ford F250 4x4.
Looked through 1979 Motor Manual (similar to Chilton's at that time) and although it doesn't show that exact model all it shows is what I remember, which was a spring going from carb linkage to manifold, which was for tension on throttle return, and gas pedal. The other which would be for choke was simply the thermostatic coil and housing that attached at end of rod that choke was attached to on side of carburetor. When cold, it would retract the coil inside the housing, which in turn would rotate and close choke for cold starts, and as engine warmed up, it would expand and rotate opposite direction and pull choke off. Could this be what your looking for?
Dec 20, 2009 | 1982 Ford F 250
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
2,658 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
