Question about Ovens
Need part for an older Gibson wall oven
Need new thermostat for a Gibson wall oven, model #BR60G-1. Any suggestions? Thanks
    Problem Solver:
  • 18 Answers
IF YOU CAN NOT FIND ONE ONLINE HAVE SOMEONE INSTALL A GENERIC THERMOSTAT BUT BE SURE THEY ARE KNOWLEDGABLE TO DETERMINE PROPER VOLTS / WATTAGES
Posted on Apr 23, 2014
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
Do you have a thermonstate for a preway wall over - model 501-1
  • Range/Stove/Oven Thermostat Parts In Stock from ... www.repairclinic.com/.../a13c24/Range-Stove-Oven-Thermostat-Parts Shop for your Range/Stove/Oven Thermostat from our ... What is a model ... Repair Help. SEARCH. Range/Stove/Oven. Thermostat. Clear All. Range/Stove/Oven Thermostat ...
  • Preway Wall Oven Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Preway Parts Shop the best selection of Preway wall ovens repair parts and accessories at Sears PartsDirect. ... Preway Wall Oven Parts ... Model retention may be affected by your ...
  • Preway Oven - Network54 www.network54.com/Forum/124162/message/1109513545/Preway+Oven Preway Oven February 27 2005 at ... I like you was searching for information on parts for a Preway wall oven we have in our ... I have the manual on the oven. The ...
  • Mar 24, 2016 | Ovens
    Where could I find older model thermostat replacement for Kenmore 2784218590 Model # Thermostat Part # 326542
    You're going to be hard pressed to find that exact part. What I would do is start looking into replacing it with a universal thermostat. Here's one that I've used before that usually works with very little modification:
    Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
    Give it a shot. What have you got to lose? It's cheaper than buying a new wall oven!
    Good luck
    Oct 23, 2014 | Ovens
    Older Gibson wall oven part needed
    Try www.repairclinic.com
    A good source for appialnce parts.
    Apr 21, 2014 | Ovens
    I have an older model gibson self cleaning oven. How do I start the self cleaning process. No manual. Thanks.
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Sep 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Door lock light blinking ,oven wont work on a older gibson self cleaning oven.
    It sounds to me that the door lock switch itself is stuck in the "on" position. If you don't use the self-cleaning feature, I would suggest simply disconnecting the switch. If you DO use the self-cleaning feature, you may want to consider replacing the switch or inspect it to make sure there isn't debris, grease, etc., stuck in it, making it stuck on all the time.
    I hope this helps! :) Please let me know if you need any further assistance in this matter and I'll be more than happy to help!
    Feb 21, 2010 | Ovens
    I need parts for an older tappan wall oven..model Z12-1449-00 ...a thermostat and thermostat knob
    It's going to be hard to look up the old model numbers, but there is a number on the old thermostat that might help.I may possibly have one but have no way to look up the specific model.
    Jan 21, 2010 | Ovens
    Oven will not turn off on older Kenmore range
    Your oven thermostat has gone faulty. You need to unplug power from the wall. Remove panel that allows access to oven thermostat, Remove knob and see what type of retaining method it has to secure it to the oven. (Does it have a nut or does it have 2 screws holding itself in position.?). How thick is the dial shaft?(5 or6 or 7 mm.thick). With that information, look now at the body of the thermostat. It should have a number sequence in the form of a sticker on it. Write it down. Phone the spares suppliers and quote them the stove model number with the other relevant items you wrote down to ensure the correct thermostat. Note, never remove wires until you are ready to transfer them one at a time from one thermostat to the other until transfer is complete. Reassemble completely and check.
    Oct 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    I have a KEBI17DBL8 Oven that will not work after using the self clean cycle. Should I get the thermostat replaced or but a new oven?
    No, no need to get a thermostat or replace the unit...yet.
    sounds like a tripped hi-limit thermo.
    that model number looks like a double oven wall unit, correct ? if so, big job. if not awesome. if it is, it's hard only because these are heavy. (alot of techs like myself have "wall oven carts" that allow me to remove it fairly easy) you might not have to pull it out though if it's not a wall oven, my bad.
    however, I think it may be the older unit's manufactured by "Dacor". if so the limit switch on most of those ranges is a "non-resetable" style. meaning you'll have to replace the themal cut-out or aka thermal switch.
    *FIRST, unplug the unit or shut off the breaker.
    the hi-limit is located by the latch/lock assembly, so you'll need to dismantle the unit to a degree. if it's a free standing range, it's pretty easy. lift the top and the latch/lock access panel is located right there.
    you'll need to determine the "why" as well of course. did the cooling fan/blower fail (#4173004), or the cooling fan therostat (#4173008) ?
    the part number you'll need for the thermal switch failure replacement is #814505. check the old one by ohming it out first of course.
    hope that helps,
    good luck
    Sep 26, 2009 | KitchenAid Ovens
    My maytag is an older model i can't afford to replace right now. its a wall unit . It had a long stick like thing inside the oven, assumed thermostat, and it broke off. The temperature stays on high , it...
    Hi you can order the thermostat and it is easy to replace, you will need the make , model and s/n to get the cocorrect part if you need to to fine the oven control just get back to me ,
    Dec 08, 2008 | Maytag CWE4800A Electric Single Oven
    Ovens Logo
    63 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
